WebUI hardening
I just installed NetBird on a dedicated server that I will be using soley for VPN purposes and thus needs to be hardened. In particular, the WebUI, without MFA, being freely accessible, bothers me a lot.
I am using the default Traefik-based reverse proxy setup and what I would like to achieve is that I can use port forwarding over SSH to access the webUI. That said, I am far more experienced with Caddy than Traefik… so I need a pointer here :slight_smile:
Basically, I want to restrict the webUI to only be accessible from the local maschine when using a tunnel (ssh -L 8080:server:80 user@server). Any advice?
  1. Use the install script to create the docker-compose setup.
  2. Set the reverse proxy to the default Traefik one (which is the default)
  3. Create the initial user in the web interface
I only want the webUI “hidden”. The rest - signaling, relay, etc., should be completely public so the VPN works, obviously. :slight_smile: My goal is to thus introduce some hardening.
(I am aware MFA is coming, I saw the Github ticket, but I still would like to go forward with the hardening.)
No.
netbird version 0.67.1
Netbird Dashboard: 2.36.0
No. This server is 100% dedicated to Netbird. I only plan to set up some form of mdns/broadcast traffic proxying to handle a few aspects WireGuard does not cover purely on L3.
Output:
 netboi.netbird.selfhosted:
  NetBird IP: 10.0.0.2
  Public key: XXry/kDxu9vKijSUPAyJwWLGibnwg10tK2qYH3knwFA=
  Connection type: P2P
  ICE candidate (Local/Remote): host/host
  ICE candidate endpoints (Local/Remote): 100:::51820/100::1:51820
  Relay server address: rels://anon-FANQ7.domain:443
  Last connection update: 29 minutes, 28 seconds ago
  Last WireGuard handshake: 1 minute, 19 seconds ago
  Transfer status (received/sent) 33.3 KiB/23.2 KiB
  Networks: 10.1.0.0/24
  Latency: 7.924326ms
  [INFO] SYSTEM (30ac0b93-75ec-4387-969b-d58879db9c86)
    Time: 35 minutes, 31 seconds ago
  [INFO] SYSTEM (fada3ea7-baaa-44cc-b735-f669824de0c0)
    Time: 29 minutes, 28 seconds ago
  [INFO] SYSTEM (68c5f6f9-a794-482f-b1e2-eceb5bc35e2d)
    Time: 26 minutes, 42 seconds ago
OS: linux/arm64
Daemon version: 0.67.1
CLI version: 0.67.1
Management: Connected to https://anon-FANQ7.domain:443
Signal: Connected to https://anon-FANQ7.domain:443
  [stun:anon-FANQ7.domain:3478] is Checking...
  [rels://anon-FANQ7.domain:443] is Available
FQDN: drachennetz.netbird.selfhosted
NetBird IP: 10.0.0.1/24
Interface type: Kernel
Lazy connection: false
SSH Server: Enabled
Peers count: 1/1 Connected
Create and upload a debug bundle
Not really applicable here? I can upload one - but I doubt this matters for this case.
None - not applicable.
This installation is as fresh as can be - the bird literally hatched about half a hour ago :slight_smile: I am migrating from Headscale to Netbird currently.
There isn’t directly a way of doing this without also breaking the API that Netbird depends on for it’s communication with the VPN (when the connection isn’t made yet, like authentication). Furthermore, to authenticate users, you’d also need to confirm credentials and from a user side. This can only be done with the WebUI.
However, what you CAN do, is setup SSO (like authentik) and force people to authenticate/MFA through that before logging into Netbird. See the following documentation:
That should get you roughly on the way.
