Support for Multiple Exit Nodes with Load Balancing
Hi team, this isn’t an issue, I’d like to understand how to setup multiple exit nodes and load balance them. We are building a setup for our client who needs public IPs from a specific CIDR, no matter where he is, so that he can access the internal assets . To achieve this, I’ve self-hosted NetBird in Azure. I’ve setup two exit nodes (VMs) and assigned them public IP from the purchased public IP CIDR range our clients own.
How can I now setup load balancing between these two exit nodes and send the traffic to the internet from connected clients? Is my question wrong? Is NetBird not built for this? I don’t know, provide a solution.
PS: The reason we need a CIDR public IPv4 range instead of a single public IP is that certain public services are blocking us due to high traffic from our client’s public IP and hence we’d want to use a CIDR range.
If I recall correctly NetBird has an option like this in the original networks feature. You can select a group of peers that’ll become the exit node of a specific group. Assuming it load balances between the groups.
