Reverse Proxy access to my service (domain) is encountering 502, but randomly / not always / not always from all clients. The problem is not on a request base, more one a auth/time and client basis.
After a while, it may be working, after another while not anymore.
When it is not working from my client 1 (same network), it can be working from client 2. Sometimes it works from both. Its the same with different networks (like local and mobile).
When my target service works on lets say my desktop-clients firefox tab, i can open up a incognito tab on the same browser, give my password and I get netbird error pages with 502. The other tab continues working. If i open up another browser - again 502, whatever I do.
Sometimes deleting browser-cache and restart browser helps, sometimes not.
It happens on a quite regular basis. My feeling is some kind of limitations on auth/connection, once it works and I keep using the target resource, it keeps working. As soon as I pause using it some time, chance for failure is high. Maybe some kind of rate limiting, auth session, some other timing thing on network or dns.
Target service docker (bridge mode) on same Synology (IP 172.22.0.6)
netbird peer on Docker bridge mode (rootless) on a Synology (IP 172.17.0.3)
I added the netbird peer to the target service network as well to make them see each other.
(IP 172.22.0.7)
- netbird cloud management setup:
2 peers (only one active, the other is for testing purposes)
Network “xyz” with ressource “172.22.0.6/32”
Policy for tcp, port 8080 only
custom domain zzz.mydomain .de (validated)
a reverse proxy service for a subdomain myservice.zzz.mydomain .de/ with target the ressource above on port 8080 and authentication password.
Whereevery I can give a group to an entity, i added one, let say “yyy” to bind it together.
I can always reach the target service with wget in the netbird peer console! Synology Firewall is disabled for now.
The target service is also available on the docker host network, lets say 192.168.178.17:8080 with no problem at all.
The target service log is not showing any problems.
After authentication I expect the target service to show up continuously. Ideally even after coming back to my browser tab 3 days later I expect the auth page again and then the target service to show up. Also i expect the target service to be working multiple times on the same client in different browser/incognito tabs (after successful auth).
Yes
latest / today: 0.6.8 (but same problem on 0.6.7, did a lot of troubleshooting on that version before)
(rootless and non-rootless)
No.
netbird status -dA:
proxy-<<<removed>>>-28-69.netbird.cloud:
NetBird IP: <<<removed>>>
Public key: Tapmxq9B/0+2m+jEIlHCW36kAXxCUBZMfYcLfaF5rmM=
Connection type: P2P
ICE candidate (Local/Remote): host/srflx
ICE candidate endpoints (Local/Remote): <<<removed>>>
Relay server address: rels://streamline-de-fra1-3.relay.netbird.io:443
Last connection update: 23 minutes, 18 seconds ago
Last WireGuard handshake: 1 minute, 45 seconds ago
Transfer status (received/sent) 9.7 KiB/13.2 KiB
Latency: 10.993254ms
m-pxl9.netbird.cloud:
Public key: <<<removed>>>
Status: Connecting
Connection type: -
Last connection update: 26 minutes, 26 seconds ago
Last WireGuard handshake: -
[INFO] SYSTEM (601ad28f-5660-466d-b50e-1ccf1eb4478a)
Time: 23 minutes, 18 seconds ago
[...<<<removed>>>....]
[INFO] SYSTEM (a7784121-13be-4130-a6de-29f1d8ac9978)
Time: 13 minutes, 43 seconds ago
[INFO] SYSTEM (15ce3c25-5bd6-4c93-998f-694cf705f1f4)
OS: linux/amd64
Daemon version: 0.68.0
CLI version: 0.68.0
Management: Connected to https://api.netbird.io:443
Signal: Connected to https://signal.netbird.io:443
[stun:stun.netbird.io:443] is Checking...
[stun:stun.netbird.io:5555] is Checking...
[turns:turn.netbird.io:443?transport=tcp] is Checking...
[rels://streamline-de-fra1-3.relay.netbird.io:443] is Available
FQDN: <<<removed>>>.netbird.cloud
Interface type: Userspace
Lazy connection: false
Networks: 172.22.0.6/32
Peers count: 1/2 Connected
f79e391890ab27fb37c88b3b4be7011e22aa2e5ca6f38ffa9c4481884941f726/0ccbc854-f02e-4156-8a5d-80da06292117
- I walked through the troubleshooting doc for 502 issues → in my eyes, none of the scenarios match to my issue
- I do not see any critical issues (afaik) in the peer logfiles
- During the uploaded logfile I was in TRACE, I saw successfull log entries of the peer log, but not unsuccessful ones (except in netbird proxy activity). The requests from reverse proxy, so I assume the requests did not seem to get there at all.
- I used rootless and “standard” peer image
- I tried without auth, no change
- I tried with netbird domain instead of custom domain, no change
- I tried with a open policy (all instead of tcp 8080)
- I tried targeting the synology IP/docker host with 8080, does not help from outside (works locally)
- I tried different browsers/incognito modes…, does not help consistently
- Disabled other VPN software
- Checked firewall settings
