SSO doesnt work and cant create Identity provider
I tried to enable SSO for a service , but when opening the service i get a “authentication service unavailable” error, the proxy logs show:
`2026-06-26T22:21:52.592Z WARN [scheme: oidc] proxy/internal/auth/middleware.go:531: authentication infrastructure error: get OIDC URL: rpc error: code = Canceled desc = context canceled
2026-06-26T22:21:52.592Z DEBG proxy/internal/accesslog/middleware.go:87: response: request_id=method=GET host=service..*** path=/ status=502 duration=2982ms source=172.30.0.1 origin=auth service=*** account=***
2026-06-26T22:21:54.663Z WARN [scheme: oidc] proxy/internal/auth/middleware.go:531: authentication infrastructure error: get OIDC URL: rpc error: code = Canceled desc = context canceled
2026-06-26T22:21:54.663Z DEBG proxy/internal/accesslog/middleware.go:87: response: request_id=d8vfmv0mmqtc73d3urbg method=GET host=service.. path=/icon.svg status=502 duration=6344ms source=...origin=auth service= account=
2026-06-26T22:22:03.873Z WARN [scheme: oidc] proxy/internal/auth/middleware.go:531: authentication infrastructure error: get OIDC URL: rpc error: code = FailedPrecondition desc = create OIDC provider: Get "https://netbird.***.***/oauth2/.well-known/openid-configuration": dial tcp ...:443: i/o timeout
2026-06-26T22:22:03.873Z DEBG proxy/internal/accesslog/middleware.go:87: response: request_id=**** method=GET host=service.. path=/favicon.ico status=502 duration=30002ms source=... origin=auth service=*** account=***
2026-06-26T22:22:19.560Z WARN [scheme: oidc] proxy/internal/auth/middleware.go:531: authentication infrastructure error: get OIDC URL: rpc error: code = FailedPrecondition desc = create OIDC provider: Get "https://netbird.***.***/oauth2/.well-known/openid-configuration": dial tcp ...:443: i/o timeout
2026-06-26T22:22:19.560Z DEBG proxy/internal/accesslog/middleware.go:87: response: request_id=*** method=GET host=service.. path=/ status=502 duration=30002ms source=... origin=auth service=*** account=***`
When I try to create a Identity provider for example Authentik and click on i get the following error:
Error: Identity provider issuer is unreachable: get "https://authentic..***:***/.well-known/openid-configuration": context deadline exceeded (client.timeout exceeded while awaiting headers)
  1. Go to Reverse Proxy / Services
  2. Edit HTTPS Service
  3. Go To authentication
  4. Add SSO
  5. Save
  6. Open the edited service
A SSO Page
NetBird version: v0.74.1
no
netbird status -dA
desktop-8rstaj2.anon-jthL0.domain:
NetBird IP: 100.119.22.246
NetBird IPv6: 2001:db8:ffff::2
Public key: p4QgtNOd8EuArmGcKL/Rg/O5zQLGrGR55TEI6LpM8HM=
Connection type: P2P
ICE candidate (Local/Remote): host/prflx
ICE candidate endpoints (Local/Remote): 2001:db8:ffff:::51820/2001:db8:ffff::1:51820
Relay server address: rels://netbird.anon-kAnLy.domain:443
Last connection update: 4 minutes, 7 seconds ago
Last WireGuard handshake: 2 minutes, 2 seconds ago
Transfer status (received/sent) 32.2 KiB/72.7 KiB
Latency: 2.975639ms
proxy-d93cg9r8tp1c73cntseg-51-244.anon-jthL0.domain:
NetBird IP: 100.119.51.244
NetBird IPv6: 2001:db8:ffff::3
Public key: HIqPaDHOKANSO33CI6mDgbNXUJATXE92vKtuczalpls=
Connection type: Relayed
Last connection update: 1 hour, 29 minutes ago
Last WireGuard handshake: 15 seconds ago
Transfer status (received/sent) 58.3 KiB/382.7 KiB
-authentic-docker.anon-jthL0.domain:
NetBird IP: 100.119.62.229
NetBird IPv6: 2001:db8:ffff::4
Public key: GqIBqJ8oQy7B4I3OsHc3fCUt+wYwud/3eVuBmEC7+FQ=
ICE candidate endpoints (Local/Remote): 192.168.251.94:51820/198.51.100.0:51820
Last connection update: 4 days ago
Last WireGuard handshake: 1 minute, 48 seconds ago
Transfer status (received/sent) 683.3 KiB/944.9 KiB
Latency: 314.763µs
debian-trixie-latest-amd64-base.anon-jthL0.domain:
NetBird IP: 100.119.189.0
NetBird IPv6: 2001:db8:ffff::5
Public key: hf7dMSQJhX7fIbNsIZflV6858e9U9q+cvPHOhIxE+k4=
Last WireGuard handshake: 17 seconds ago
Transfer status (received/sent) 4.4 KiB/14.1 KiB
Latency: 11.625234ms
[INFO] SYSTEM (214aefc9-cf66-4848-9309-ddd05656cfcf)
Time: 1 day, 20 hours ago
[INFO] SYSTEM (bdee23ec-0bbe-4638-9529-bf8fac4b12df)
[INFO] SYSTEM (b7515f88-1d48-4198-bbc3-ed7e2154a797)
Time: 1 day, 1 hour ago
[INFO] SYSTEM (cb66ea90-ee62-41ac-8b4d-a0e084718005)
Time: 15 hours, 23 minutes ago
[INFO] SYSTEM (9db0fcec-d959-4cb4-bcf6-6795bbe7dcc5)
Time: 15 hours, 22 minutes ago
[INFO] SYSTEM (8605078a-7f2a-4eee-bb5b-66828166db3e)
Time: 15 hours, 21 minutes ago
[INFO] SYSTEM (b068be10-11cb-462f-8898-22a8039fa4be)
Time: 15 hours, 12 minutes ago
[INFO] SYSTEM (ca57f608-f68e-4ec5-9228-6dae8fed9a68)
Time: 1 hour, 29 minutes ago
[INFO] SYSTEM (46753107-5fdf-4a56-8eea-4dfb2a578710)
[INFO] SYSTEM (30425a62-3957-4fb5-9f50-6cebe683500c)
Time: 1 hour, 19 minutes ago
OS: linux/amd64
Daemon version: 0.73.2
CLI version: 0.73.2
Management: Connected to https://netbird.anon-kAnLy.domain:443
Signal: Connected to https://netbird.anon-kAnLy.domain:443
[stun:netbird.anon-kAnLy.domain:3478] is Available
[rels://netbird.anon-kAnLy.domain:443] is Available via ws
[9.9.9.9:53, 149.112.112.112:53] for [anon-shRZf.domain] is Available
FQDN: stopdocker.anon-jthL0.domain
NetBird IP: 100.119.247.210/16
NetBird IPv6: 2001:db8:ffff::6/64
Interface type: Kernel
Wireguard port: 51820
Lazy connection: true
Peers count: 4/4 Connected
netbird debug for 1m -AS -U
b00aa6a4e303646a93fc08172871e8413b8cd5b3ef913a514c395c1b694cafa0/04dc4dc2-727d-444a-8dff-cb0cd59b0a98
Uploaded files are automatically deleted after 30 days.
If applicable, add screenshots to help explain your problem.
Make sure that the domain you are trying to authenticate with is NOT dependend on NetBird.
That line indicates that your Netbird server is unable to reach your SSO, meaning it can’t build the authentication client it requires to function, this could either be because your netbird server runs netbird and you messed with the dns. Or your dns is messed up on the server itself.
Thank you for the answer.
I am not quiet sure, i get your answer.
What do you mean by make sure that the domain you are trying to authenticate with is NOT dependend on NetBird? Of course its somewhat dependant on netbird, thats what i use as reverse proxy or traefik, but i manage it in netbird.
I didnt change anything in the dns manually and I don´t get the first part.
The solution was to add
extra_hosts:
- "netbird.domain.com:172.30.0.10"
to netbird-server in the compose.
