Solution: How to update password if forgotten
A brief guide to update password on Netbird user for selfhosted env:
The idea is to access the userdatabase and table “password” to update and manipulate directly.
It might recommanded to stop container with “docker compose stop” before running the script, and afterward “docker compose start” - but it worked for me while having the containers running while running the script.
You need the (on ubuntu/debian)
apt install python3-bcrypt python3-aiosqlite
executing
docker compose volumes
DRIVER VOLUME NAME
local netbird_netbird_data
local netbird_netbird_traefik_letsencrypt
local netbird_netbird_proxy_certs
shows you the relevant volume.
Adjust the script TARGET_USERNAME and DB_PATH and BACKUP_DIR
import sqlite3
import bcrypt
import shutil
import os
from datetime import datetime
— USER CONFIGURATION —
TARGET_USERNAME = “admin”            # The value to search for in username or email
NEW_PLAINTEXT_PASSWORD = “MySecretPassword123!”
DB_PATH = “/var/lib/docker/volumes/netbird_netbird_data/_data/idp.db”  # Path to the file inside the volume
BACKUP_DIR = “/root/netbird/backups”
def generate_hash(password: str):
“”“Generates a bcrypt hash with a cost factor of 10.”“”
password_bytes = password.encode(‘utf-8’)
salt = bcrypt.gensalt(rounds=10)
hash_bytes = bcrypt.hashpw(password_bytes, salt)
return hash_bytes.decode(‘utf-8’)
def create_backup(source_path):
“”“Creates a timestamped backup of the database file.”“”
if not os.path.exists(BACKUP_DIR):
os.makedirs(BACKUP_DIR)
timestamp = datetime.now().strftime("%Y%m%d_%H%M%S")
backup_path = os.path.join(BACKUP_DIR, f"idp_backup_{timestamp}.db")
try:
    shutil.copy2(source_path, backup_path)
    print(f"Backup created: {backup_path}")
    return True
except Exception as e:
    print(f"Backup failed: {e}")
    return False
def update_db():
“”“Uses TARGET_USERNAME and NEW_PLAINTEXT_PASSWORD to update the DB.”“”
# 1. Generate the hash first
new_hash = generate_hash(NEW_PLAINTEXT_PASSWORD)
try:
    conn = sqlite3.connect(DB_PATH)
    cursor = conn.cursor()
    # 2. Execute query using the global variables
    query = "UPDATE password SET hash = ? WHERE username = ? OR email = ?"
    cursor.execute(query, (new_hash, TARGET_USERNAME, TARGET_USERNAME))
    if cursor.rowcount == 0:
        print(f"No user found matching: {TARGET_USERNAME}")
    else:
        conn.commit()
        print(f"Success: Hash updated for '{TARGET_USERNAME}'")
except sqlite3.Error as e:
    print(f"SQLite error: {e}")
finally:
    if 'conn' in locals():
        conn.close()
if name == “main”:
if not os.path.exists(DB_PATH):
print(f"Error: Database not found at {DB_PATH}")
else:
if create_backup(DB_PATH):
update_db()
Moved to Tips and Guides & added formatting to the original message, additionally turned it into a wiki.
