Custom domain shows Active/verified in Reverse Proxy Custom Domains, but any service on it stays stuck at “Issuing certificate…” forever on NetBird Cloud (free plan, eu1 cluster). The built-in free domain on the same cluster issues its certificate instantly. This is not self-hosted.
- Add custom domain mohandl3g.ly under Reverse Proxy, Custom Domains.
- Add wildcard CNAME *.mohandl3g.ly to eu1.netbird.services in Cloudflare, DNS-only (grey cloud).
- Click Verify Domain, and wait for status to become Active.
- Create a reverse proxy service for example jellyfin.mohandl3g.ly.
- Service stays at “Issuing certificate…” for hours; opening the URL shows the “certificate not issued” error.
The proxy should automatically issue a Let’s Encrypt certificate via ACME (tls-alpn-01 on port 443) and the service should become Active.
Yes.
Client 0.76.3 (running in Docker on a Windows host).
No.
netbird status -dA output:
proxy-d9svd03l0ubs73egc660-146-234.netbird.cloud:
NetBird IP: 100.102.146.234
Connection type: Relayed
Relay server address: rels://streamline-de-fra1-9.relay.netbird.io:443
proxy-d9svd03l0ubs73egc650-184-167.netbird.cloud:
NetBird IP: 100.102.184.167
Relay server address: rels://streamline-es-mad1-0.relay.netbird.io:443
FQDN: mohandl3g-docker.netbird.cloud
NetBird IP: 100.102.138.213/16
Management: Connected to https://api.netbird.io:443
Signal: Connected to https://signal.netbird.io:443
Peers count: 2/2 Connected
f79e391890ab27fb37c88b3b4be7011e22aa2e5ca6f38ffa9c4481884941f726/ceb6e079-aa91-4c4c-aea5-595552cb8604
- Disabled other VPN software
- Checked firewall settings
