I was wondering what percentage of connections go through relay servers?
Like explained on the Slack, there isn’t a direct percentage to give. The amount of servers that connect to the relay depends on the amount of servers that need to use the relay. Instead of just a direct P2P connection from wireguard to wireguard. To many factors to give an exact % with.
