Poor Netbird SelfHosted traffic throughput
I’m experiencing very poor Netbird traffic throughput on my hardware. About 10 months ago, I had Netbird running on the same hardware and connection, but back then Netbird had a port exposed directly without using a proxy server. Now I’m using Caddy as a proxy for the entire Proxmox server.
Back then, I was easily getting ~180-200 Mbps through Netbird and the exit-node to the Internet on the same machine. Now I’m getting a maximum of 8-12 Mbps on the same hardware, and on top of that, connections always go through a relay even though I have a public IP and properly forwarded ports.
I’m testing the connection from an Android 16 phone over LTE; without using Netbird, I get 200–250 Mbps, but after enabling the tunnel and using an exit node from Debian, I always get a maximum of 12 Mbps.
Network diagram:
Router with OpenWrt and a public IP > Proxmox > Debian on VM – Docker with Caddy and a Netbird server inside. I also use Caddy as a proxy for my other self-hosted websites
Plus a Netbird “client” installed directly on Debian from the Netbird repository.
The client exposes the LAN and acts as an exit node to the Internet.
Port Forwards: 80, 443, 3478/UDP, 600/UDP → Docker VM
I’m not sure if I did the right thing, but I also opened port 600 for WireGuard and ran the “client” on Debian with the following additional option:
–wireguard-port 600
On all peers i have enabled: lazy connection, rosenpass, preshared-key (same on all peers)
Debug Bundle: 6754d3f72e446a597400b6f0d0eb3a58f8ff134b2f09c5af3dc06f0bf094e401/14904cdd-73da-46f5-ac28-46927a4b0d08
linux.netbird.camis:
 NetBird IP: 100.64.1.1
 Public key: ********
 – detail –
 Connection type: Relayed
 Relay server address: rels://netbird.*****:443
 Last connection update: 2 minutes, 49 seconds ago
 Last WireGuard handshake: 44 seconds ago
 Transfer status (received/sent) 5.8 KiB/5.3 KiB
 Quantum resistance: true
android.netbird.camis:
 NetBird IP: 100.64.2.1
 – detail –
 Relay server address: rels://netbird.******:443
 Last connection update: 50 seconds ago
 Last WireGuard handshake: 48 seconds ago
 Transfer status (received/sent) 7.5 MiB/18.9 MiB
 [INFO] SYSTEM ()
   Time: 9 minutes ago
OS: linux/amd64
Daemon version: 0.72.2
CLI version: 0.72.2
Management: Connected to https://netbird.*****:443
Signal: Connected to https://netbird.*****:443
 [stun:netbird.:3478] is Available
 [rels://netbird.*****:443] is Available
 [10.0.10.1:53] for [.] is Available
FQDN: proxmox.netbird.camis
NetBird IP: 100.64.0.1/21
Interface type: Kernel
Wireguard port: 600
Quantum resistance: true (permissive)
Lazy connection: true
Networks: 0.0.0.0/0
Peers count: 2/2 Connected
Caddyfile:
netbird.***** {
Native gRPC (needs HTTP/2 cleartext to backend)
@grpc header Content-Type application/grpc*
reverse_proxy @grpc h2c://netbird-server:80
# Combined server paths (relay, signal, management, OAuth2)
@backend path /relay* /ws-proxy/* /api/* /oauth2/*
reverse_proxy @backend netbird-server:80
# Dashboard (everything else)
reverse_proxy /* netbird-dashboard:80
I haven’t had time to investigate this at all yet, but, I think I too am using Caddy (I have the Netbird Reverse Proxy setup), and have also been a little disappointed at the throughput (Again, I haven’t investigated too much, so perhaps more CPU cores needed, but I don’t think the NB boxes are at full utilization), but the main reason I am posting is because I too have seen relay mode in use when I would expect direct P2P would be possible:
  Relay server address: rels://nb.REDACTED.com:443
I haven’t even got as far is working out exactly how relay mode works - does the WG traffic get funnelled through the NB management server somehow?
