Policies - Various UDP/TCP/ICMP definitions in one rule
If I want to open different UDP/TCP ports for a service, I have to create multiple policies. This is difficult to manage.
When creating a policy, several entries can be created under “Protocol.” These include TCP, UDP, and ICMP. This means that I select the protocol and can then specify the ports. If necessary, I can enable multiple protocols. This allows me to create a policy for a service.
Create multiple policies and group them with the description.
