/peers loading indefinitely
Hi NetBird team, community members,
I’ve been trying to set up a self-hosted NetBird deployment using Keycloak as the OIDC provider with Github as an identity provider. The dashboard login via Github works fine, but the /peers page never finishes loading. I have gone back to the initial setup from the documentation: Advanced guide - NetBird Docs.
Here’s the setup I’m using:
  • Self-hosted using the official Docker compose setup (latest version 0.59.7) & Ubuntu 24.04 LTS
  • Keycloak realm configured with netbird-client and netbird-backend clients, and Github as an IdP
  • Environment variables follow the standard docker-compose template from configure.sh
  • No reverse proxy is used — everything is exposed directly via the dashboard and management containers on a single IP/domain.
Symptoms:
  • Login works, GitHub SSO completes successfully
  • /peers keeps loading indefinitely
I’ve spent ~2 months(weekends) debugging this. I’ve checked:
  • Docker container network connectivity
  • Keycloak client scopes, audience, and token types
  • Environment variables in dashboard and management containers
  • Firewall / VPN conflicts (none exist)
  • NetBird client troubleshooting steps and documentation
Despite all of this, the /peers page still does not load. Upon rebuilding everything from documentation I hit the same screen, different error. I can provide anonymized debug logs and status output if needed.
I’m hoping you can help identify whether there’s a configuration step I’m missing for self-hosted deployments with Keycloak & Github SSO, or if this is a known issue with latest version Docker images. The infrastructure_files/artifacts combined with setup.env and documentation is not clear enough and misses steps in order to complete the self-hosted deployment. Initially I followed only the steps from documentation but never got it working. I would very much love to get this working and use it for my infrastructure. After achieving a working setup I would be able to implement it into my Github workflow or Ansible playbook for further deployments/updates.
I can also share my anonymized /infrastructure_files/artifacts/docker-compose.yml if that would be useful.
Anonymized /infrastructure_files/setup.env that I use:
NETBIRD_DOMAIN="vpn.mydomain.io"
NETBIRD_TURN_DOMAIN=""
NETBIRD_TURN_EXTERNAL_IP=""
NETBIRD_AUTH_OIDC_CONFIGURATION_ENDPOINT="https://auth.mydomain.io/realms/netbird/.well-known/openid-configuration"
#NETBIRD_DASH_AUTH_USE_AUDIENCE=false
NETBIRD_AUTH_AUDIENCE="netbird-client"
NETBIRD_AUTH_CLIENT_ID="netbird-client"
NETBIRD_AUTH_SUPPORTED_SCOPES="openid profile email offline_access api"
NETBIRD_USE_AUTH0="false"
NETBIRD_AUTH_DEVICE_AUTH_PROVIDER="none"
NETBIRD_AUTH_DEVICE_AUTH_CLIENT_ID="netbird-client"
NETBIRD_AUTH_DEVICE_AUTH_AUDIENCE=$NETBIRD_AUTH_AUDIENCE
NETBIRD_AUTH_DEVICE_AUTH_SCOPE="openid"
NETBIRD_AUTH_DEVICE_AUTH_USE_ID_TOKEN=false
NETBIRD_MGMT_IDP="keycloak"
NETBIRD_IDP_MGMT_CLIENT_ID="netbird-backend"
NETBIRD_IDP_MGMT_CLIENT_SECRET="my-netbird-backend-secret"
NETBIRD_IDP_MGMT_EXTRA_ADMIN_ENDPOINT="https://auth.mydomain.io/admin/realms/netbird"
NETBIRD_DISABLE_LETSENCRYPT=false
NETBIRD_LETSENCRYPT_EMAIL="admin@mydomain.io"
NETBIRD_DISABLE_ANONYMOUS_METRICS=false
NETBIRD_MGMT_DNS_DOMAIN=netbird.selfhosted
NETBIRD_MGMT_DISABLE_DEFAULT_POLICY=false
I have checked all the Keycloak settings from Identity Providers - NetBird Docs and rebuild the directory from the Github repository (latest version).
I am completely at a loss about how this should be set up. If I follow the official documentation I always run into this screen that keeps loading /peers
Update:
I found a setting I did miss but now still stumble upon this error:
I seem to have an issue with CORS? Where/how would I fix this?
Thanks (I hope) for your assistance!
You may have to setup the port for Netbird to be able to connect with the turn server over SSL by making it reverse proxy the requests.
I had a similar problem and was able to get it to work by Proxying the management service inside the Docker network. It should look something like this inside the server block.
— API: proxy to management service —
# management container listens HTTP on port 443 (inside Docker network)
location /api/ {
    proxy_pass http://management:443;
    proxy_http_version 1.1;
    proxy_set_header Host              $host;
    proxy_set_header X-Real-IP         $remote_addr;
    proxy_set_header X-Forwarded-For   $proxy_add_x_forwarded_for;
    proxy_set_header X-Forwarded-Proto $scheme;
