I have 2 networks:
- Net A 192.168.1.1/24 via Peer A,
- Net B 192.168.1.1/24 via Peer B.
I expect peers themselves to be able to connect to both own net (LAN) and remote net (via Netbird).
Currently only one network works, no overlapping detection happens, and the other one becomes unreachable.
- 2 LANs with the same CIDR needed, with Peer in each, physically separate (home + office),
- Setup two Networks via different peers with the same CIDR (192.168.1.1/24),
- Peer A sees Net B in Netbird Desctop → Networks → All networks,
- Peer A does not see Net A/B in Overlapping networks,
- “Select” Net B from Peer A Netbird Desctop (to connect to that network),
- Go http://192.168.1.1 (both networks have origin listening) in the browser - Net B origin responds,
- Go http://192.168.1.2 (only Net A - LAN - have origin to serve) - address unreachable.
Overlapping networks detected when one of them is LAN and other is Remote.
Cloud.
No. Only Docker which also creates virtual interfaces.
netbird status -dA
netbird debug for 1m -AS -U
Uploaded files are automatically deleted after 30 days.
Alternatively, create the file only and attach it here manually:
If applicable, add screenshots to help explain your problem.
- Disabled other VPN software
- Checked firewall settings
