Network Routes & ACLs
I have a homelab setup where I’ve deployed Proxmox and created two Linux Containers (LXC). My goal is to use one LXC to publish my home network subnet (192.168.68.0/22 - TP-Link’s default) and the second LXC I intend to configure as an exit node for external users and devices that are not part of the trusted network (i.e., my homelab and known devices). I want the second LXC to be completely isolated from the rest of the trusted network and devices.
After configuring everything, I can see the correct exit node on one of the external devices. However, I’m still able to ping and access the trusted devices, despite having set up the access control lists (ACLs) and policies to completely separate the two groups.
I have not yet purchased physical equipment, such as a managed switch, to divide my home network into VLANs and create physically separate networks. How can I achieve a similar result using Netbird?
Self-hosted NetBird’s control plane.
Tailscale - LXC stopped and not running
Screenshots:
You could potentially use Networks to internally manage the switches in between. However, this only works for connections in Netbird. Not connections on your network in general. Hardware switches will always be the best way to segregate your network in VLANs
