Hello
I have a site-to-site setup where I need to route traffic between two locations. Connection between peers is stable, but the routes are not being pushed to the OS routing table.
Topology:
Office: 192.168.100.0/24 (Routing Peer: Ubuntu 22.04)
Data Center (DC): 192.168.10.0/24 (Routing Peer: Ubuntu 22.04, also hosting the Management Server)
The Issue: On the Office Peer, ip route show does not show the route to the DC network (192.168.10.0/24 dev wt0).
My Configuration in Dashboard:
Network Route: Created for
192.168.10.0/24with the DC Peer as the routing node. -
Access Control: Policies are set to “Accept” between the Office group and the DC Peer/Network.
IP Forwarding/Masquerade: Enabled on both routing peers.
Observations:
netbird statusshows the management and signal servers are connected. -
Manual addition of the route (
ip route add 192.168.10.0/24 dev wt0) temporarily fixes the connectivity, which confirms the tunnel itself is working. -
However, NetBird does not manage this route automatically.
Question: What could prevent the NetBird agent from adding the configured Network Route to the system’s routing table? Are there specific logs I should check to see why the agent is ignoring the route configuration from the Management server?
