- [client] fix MDM managementURL conflict on default-port URL echo by @riccardomanfrin in [client] fix MDM managementURL conflict on default-port URL echo by riccardomanfrin · Pull Request #6672 · netbirdio/netbird · GitHub
- [management,client] 0.75.0 release by @mlsmaycon in [management,client] 0.75.0 release by mlsmaycon · Pull Request #6473 · netbirdio/netbird · GitHub
- [client] introduce client-side event aggregation by @dmitri-netbird in [client] introduce client-side event aggregation by dmitri-netbird · Pull Request #6627 · netbirdio/netbird · GitHub
- [client] add json gateway for netbird daemon by @jnfrati in [client] add json gateway for netbird daemon by jnfrati · Pull Request #6272 · netbirdio/netbird · GitHub
- [client] fix: re-generate gateway proto files by @jnfrati in [client] fix: re-generate gateway proto files by jnfrati · Pull Request #6696 · netbirdio/netbird · GitHub
- [client] Merge v0.74.x branch by @theodorsm in [client] Merge v0.74.x branch by theodorsm · Pull Request #6700 · netbirdio/netbird · GitHub
- [doc] Update Agent Network Readme by @braginini in [doc] Update Agent Network Readme by braginini · Pull Request #6699 · netbirdio/netbird · GitHub
- [client] Fix browser relay WebSocket close and raise RDP dial timeout by @lixmal in [client] Fix browser relay WebSocket close and raise RDP dial timeout by lixmal · Pull Request #6684 · netbirdio/netbird · GitHub
- [management] add traffic filters for source and dest id by @pascal-fischer in [management] add traffic filters for source and dest id by pascal-fischer · Pull Request #6697 · netbirdio/netbird · GitHub
- [client] fix flaky test around event aggregation by @dmitri-netbird in [client] fix flaky test around event aggregation by dmitri-netbird · Pull Request #6710 · netbirdio/netbird · GitHub
- [client] Add SSO login flow timing instrumentation by @mlsmaycon in [client] Add SSO login flow timing instrumentation by mlsmaycon · Pull Request #6717 · netbirdio/netbird · GitHub
- [client,management] sync 0.74.4 changes by @mlsmaycon in [client,management] sync 0.74.4 changes by mlsmaycon · Pull Request #6727 · netbirdio/netbird · GitHub
- [management] fix duplicate operationId in OpenAPI spec by @CoderSufiyan in [management] fix duplicate operationId in OpenAPI spec by CoderSufiyan · Pull Request #6734 · netbirdio/netbird · GitHub
- [management] Add agent_network_only account setting by @mlsmaycon in [management] Add agent_network_only account setting by mlsmaycon · Pull Request #6736 · netbirdio/netbird · GitHub
- [management] Add dashboard_features account setting by @mlsmaycon in [management] Add dashboard_features account setting by mlsmaycon · Pull Request #6742 · netbirdio/netbird · GitHub
- [client] Bring the connection up in Go after SSO login by @mlsmaycon in [client] Bring the connection up in Go after SSO login by mlsmaycon · Pull Request #6744 · netbirdio/netbird · GitHub
- [client] Enable launch-on-login by default on fresh GUI installs by @mlsmaycon in [client] Enable launch-on-login by default on fresh GUI installs by mlsmaycon · Pull Request #6738 · netbirdio/netbird · GitHub
- [management] require dashboard_features.agent_network when enabling agent_network_only by @mlsmaycon in [management] require dashboard_features.agent_network when enabling agent_network_only by mlsmaycon · Pull Request #6750 · netbirdio/netbird · GitHub
- [proxy, client] Include system events in status conversion by @lixmal in [proxy, client] Include system events in status conversion by lixmal · Pull Request #6746 · netbirdio/netbird · GitHub
- [management] add logs to ephemeral delete by @pascal-fischer in [management] add logs to ephemeral delete by pascal-fischer · Pull Request #6747 · netbirdio/netbird · GitHub
- @CoderSufiyan made their first contribution in [management] fix duplicate operationId in OpenAPI spec by CoderSufiyan · Pull Request #6734 · netbirdio/netbird · GitHub
Full Changelog: Comparing v0.74.2...v0.75.0-rc.6 · netbirdio/netbird · GitHub
