- [client] Make lazy connections opt-out via NB_LAZY_CONN by @lixmal in https://github.com/netbirdio/netbird/pull/6617
- [client] Run privileged client tests natively with sudo on Linux by @pappz in [client] Run privileged client tests natively with sudo on Linux by pappz · Pull Request #6635 · netbirdio/netbird · GitHub
- [self-hosted] Remove image override logic in getting started by @mlsmaycon in https://github.com/netbirdio/netbird/pull/6636
- [management] Add vLLM support for Agent Network by @braginini in [management] Add vLLM support for Agent Network by braginini · Pull Request #6643 · netbirdio/netbird · GitHub
- [management] return nil when config is not set by @mlsmaycon in [management] return nil when config is not set by mlsmaycon · Pull Request #6642 · netbirdio/netbird · GitHub
Full Changelog: Comparing v0.74.0...v0.74.1 · netbirdio/netbird · GitHub
