- [misc] Bump the actions group across 1 directory with 9 updates by @dependabot[bot] in [misc] Bump the actions group across 1 directory with 9 updates by dependabot[bot] · Pull Request #6451 · netbirdio/netbird · GitHub
- [client] Surface DNS forwarder upstream failures via Extended DNS Errors by @lixmal in [client] Surface DNS forwarder upstream failures via Extended DNS Errors by lixmal · Pull Request #6441 · netbirdio/netbird · GitHub
- [misc] Add TARGETPLATFORM build argument to Docker build commands by @mlsmaycon in [misc] Add TARGETPLATFORM build argument to Docker build commands by mlsmaycon · Pull Request #6499 · netbirdio/netbird · GitHub
- [client] Add Auth.Stop() to cancel an in-progress interactive login by @pappz in [client] Add Auth.Stop() to cancel an in-progress interactive login by pappz · Pull Request #6486 · netbirdio/netbird · GitHub
- [client] Fix engine lifecyrcle race by @pappz in [client] Fix engine lifecyrcle race by pappz · Pull Request #6443 · netbirdio/netbird · GitHub
- [client] fix WaitStreamConnected test call after ctx signature change by @pappz in [client] fix WaitStreamConnected test call after ctx signature change by pappz · Pull Request #6503 · netbirdio/netbird · GitHub
- [misc] Add enterprise getting-started and migrate script by @bcmmbaga in [misc] Add enterprise getting-started and migrate script by bcmmbaga · Pull Request #6501 · netbirdio/netbird · GitHub
- [management] do not use meta diff for login by @pascal-fischer in [management] do not use meta diff for login by pascal-fischer · Pull Request #6502 · netbirdio/netbird · GitHub
- [management] validate meta change against posture checks by @pascal-fischer in [management] validate meta change against posture checks by pascal-fischer · Pull Request #6510 · netbirdio/netbird · GitHub
- [management] empty file check in nmap on other posturechecks by @pascal-fischer in [management] empty file check in nmap on other posturechecks by pascal-fischer · Pull Request #6511 · netbirdio/netbird · GitHub
Full Changelog: Comparing v0.73.1...v0.73.2 · netbirdio/netbird · GitHub
