- [proxy] Update package-lock.json by @heisbrot in [proxy] Update package-lock.json by heisbrot · Pull Request #5661 · netbirdio/netbird · GitHub
- [client] Unexport GetServerPublicKey, add HealthCheck method by @pappz in [client] Unexport GetServerPublicKey, add HealthCheck method by pappz · Pull Request #5735 · netbirdio/netbird · GitHub
- [client] Fix mgmProber interface to match unexported GetServerPublicKey by @pappz in [client] Fix mgmProber interface to match unexported GetServerPublicKey by pappz · Pull Request #5815 · netbirdio/netbird · GitHub
- [management] validate permissions on groups read with name by @pascal-fischer in [management] validate permissions on groups read with name by pascal-fischer · Pull Request #5749 · netbirdio/netbird · GitHub
- [management] Fix missing service columns in pgx account loader by @lixmal in [management] Fix missing service columns in pgx account loader by lixmal · Pull Request #5816 · netbirdio/netbird · GitHub
- [client] Error out on netbird expose when block inbound is enabled by @lixmal in [client] Error out on netbird expose when block inbound is enabled by lixmal · Pull Request #5818 · netbirdio/netbird · GitHub
- [client] Skip down interfaces in network address collection for posture checks by @lixmal in [client] Skip down interfaces in network address collection for posture checks by lixmal · Pull Request #5768 · netbirdio/netbird · GitHub
- [client] Fix SSH server Stop() deadlock with active sessions by @lixmal in [client] Fix SSH server Stop() deadlock with active sessions by lixmal · Pull Request #5717 · netbirdio/netbird · GitHub
- [client] Add TCP DNS support for local listener by @lixmal in [client] Add TCP DNS support for local listener by lixmal · Pull Request #5758 · netbirdio/netbird · GitHub
- [client] Fix iOS DNS upstream routing for deselected exit nodes by @mlsmaycon in [client] Fix iOS DNS upstream routing for deselected exit nodes by mlsmaycon · Pull Request #5803 · netbirdio/netbird · GitHub
- [client] Add NAT-PMP/UPnP support by @lixmal in [client] Add NAT-PMP/UPnP support by lixmal · Pull Request #5202 · netbirdio/netbird · GitHub
- [relay] Replace net.Conn with context-aware Conn interface by @pappz in [relay] Replace net.Conn with context-aware Conn interface by pappz · Pull Request #5770 · netbirdio/netbird · GitHub
- [client] Fix SSH proxy mangling shell quoting in forwarded commands by @lixmal in [client] Fix SSH proxy mangling shell quoting in forwarded commands by lixmal · Pull Request #5669 · netbirdio/netbird · GitHub
- [client] Don’t abort UI debug bundle when up/down fails by @lixmal in [client] Don't abort UI debug bundle when up/down fails by lixmal · Pull Request #5780 · netbirdio/netbird · GitHub
Full Changelog: Comparing v0.67.4...v0.68.0 · netbirdio/netbird · GitHub
