- [client] Don’t abort debug for command when up/down fails by @lixmal in [client] Don't abort debug for command when up/down fails by lixmal · Pull Request #5657 · netbirdio/netbird · GitHub
- [misc] Set signing env only if not fork and set license by @mlsmaycon in [misc] Set signing env only if not fork and set license by mlsmaycon · Pull Request #5659 · netbirdio/netbird · GitHub
- [management] Omit proxy_protocol from API response when false by @lixmal in [management] Omit proxy_protocol from API response when false by lixmal · Pull Request #5656 · netbirdio/netbird · GitHub
- [management] Replace JumpCloud SDK with direct HTTP calls by @bcmmbaga in [management] Replace JumpCloud SDK with direct HTTP calls by bcmmbaga · Pull Request #5591 · netbirdio/netbird · GitHub
- [management] Allow multiple header auths with same header name by @lixmal in [management] Allow multiple header auths with same header name by lixmal · Pull Request #5678 · netbirdio/netbird · GitHub
- [management] Fix DNS label uniqueness check on peer rename by @bcmmbaga in [management] Fix DNS label uniqueness check on peer rename by bcmmbaga · Pull Request #5679 · netbirdio/netbird · GitHub
- [misc] Replace discontinued LocalStack with MinIO in S3 test by @lixmal in [misc] Replace discontinued LocalStack with MinIO in S3 test by lixmal · Pull Request #5680 · netbirdio/netbird · GitHub
- [client] Bump go-m1cpu to v0.2.1 to fix segfault on macOS 26 / M5 chips by @lixmal in [client] Bump go-m1cpu to v0.2.1 to fix segfault on macOS 26 / M5 chips by lixmal · Pull Request #5701 · netbirdio/netbird · GitHub
- [infrastructure] Enable RPM package gpgcheck in install script by @lixmal in [infrastructure] Enable RPM package gpgcheck in install script by lixmal · Pull Request #5676 · netbirdio/netbird · GitHub
- [client] Replace iOS DNS IsPrivate heuristic with route checker by @lixmal in [client] Replace iOS DNS IsPrivate heuristic with route checker by lixmal · Pull Request #5694 · netbirdio/netbird · GitHub
Full Changelog: Comparing v0.67.0...v0.67.1 · netbirdio/netbird · GitHub
