Release Notes for v0.61.0
Fine-Grained SSH Access Control (Breaking Change)
NetBird introduces fine-grained SSH access control with support for explicit local OS users on target machines.
Administrators can now define which NetBird users or groups are allowed to connect as specific local system users, enabling safer, more predictable SSH access without relying on shared or implicit credentials.
Breaking change for self-hosted deployments
Self-hosted installations must upgrade the Management server before upgrading their clients and enabling or using the new SSH access model.
Failing to upgrade may result in SSH access issues or unexpected behavior.
Learn more at: SSH Access - NetBird Docs
Automatic Client Updates (Windows & macOS) - Beta
NetBird adds automatic client update support for Windows and macOS, helping users stay up to date with the latest fixes and features while maintaining full control over update behavior. This feature is currently in beta and administrators will be able to enable, disable, and configure a custom max version.
A few notes on the behavior:
- Update check will happen on connection
- Supported on Windows and macOS only
- Disabled by default
- Can be enabled via Settings → Client in the NetBird application. See image below:
Learn more at: Client Automatic Updates - NetBird Docs
Management Enhancements
- Added fine-grained SSH access control across client and management.
#4969
Client Enhancements
- Introduced auto-update support for the client to simplify upgrades.
#4732 - Improved management domain lookup by adding an additional timeout.
#4983 - Added Android profile switching for easier multi-profile usage.
#4884 - Fixed Linux UI flickering during state updates.
#4886 - Applied DNS host configuration only on changes to reduce unnecessary updates.
#4695
MISC
- Added FreeBSD port release job to GitHub Actions.
#4916 - Added conditional checks for FreeBSD diff file generation in CI.
#5001 - Updated to new signing pipelines v0.1.0.
#4993 - Fixed a broken image link in the README.
#4876 - Preset signal port on templates #5004
- @hey-august made their first contribution in #4876
Full Changelog: v0.60.8…v0.61.0
