- [client] Use setsid to avoid the parent process from being killed via HUP by login by @lixmal in [client] Use setsid to avoid the parent process from being killed via HUP by login by lixmal · Pull Request #4900 · netbirdio/netbird · GitHub
- [client] Fix DNS forwarder returning broken records on 4 to 6 mapped IP addresses by @lixmal in [client] Fix DNS forwarder returning broken records on 4 to 6 mapped IP addresses by lixmal · Pull Request #4887 · netbirdio/netbird · GitHub
- [management] cleanup logs by @pascal-fischer in [management] cleanup logs by pascal-fischer · Pull Request #4933 · netbirdio/netbird · GitHub
- [management] monitoring updates by @pascal-fischer in [management] monitoring updates by pascal-fischer · Pull Request #4937 · netbirdio/netbird · GitHub
- [management] Fix sync metrics by @pascal-fischer in [management] Fix sync metrics by pascal-fischer · Pull Request #4939 · netbirdio/netbird · GitHub
- [management] remove context from store methods by @pascal-fischer in [management] remove context from store methods by pascal-fischer · Pull Request #4940 · netbirdio/netbird · GitHub
- [management] Approve all pending peers when peer approval is disabled by @bcmmbaga in [management] Approve all pending peers when peer approval is disabled by bcmmbaga · Pull Request #4806 · netbirdio/netbird · GitHub
- [iOS] Add force relay connection on iOS by @doromaraujo in [iOS] Add force relay connection on iOS by doromaraujo · Pull Request #4928 · netbirdio/netbird · GitHub
- [relay-server] Add health-check agent recognition to avoid error logs by @pappz in [relay-server] Add health-check agent recognition to avoid error logs by pappz · Pull Request #4917 · netbirdio/netbird · GitHub
- [ci] Add local lint setup with pre-push hook to catch issues early by @pappz in [ci] Add local lint setup with pre-push hook to catch issues early by pappz · Pull Request #4925 · netbirdio/netbird · GitHub
- [management] use xid as request id for logging by @pascal-fischer in [management] use xid as request id for logging by pascal-fischer · Pull Request #4955 · netbirdio/netbird · GitHub
- [client] Add stack trace for bundle by @pappz in [client] Add stack trace for bundle by pappz · Pull Request #4957 · netbirdio/netbird · GitHub
- [client] Fix deadlock in delayed WG update function by @pappz in [client] Fix deadlock in delayed WG update function by pappz · Pull Request #4953 · netbirdio/netbird · GitHub
Full Changelog: Comparing v0.60.7...v0.60.8 · netbirdio/netbird · GitHub
