Native SSH Access & OpenSSH Integration
NetBird v0.60.0 ships a complete rewrite of SSH access. Every peer can now run a built-in SSH server, giving you identity-aware, private SSH access over your NetBird network — using either the netbird ssh command or your existing OpenSSH clients.
Highlights
Built-in SSH server on every peer - Enable with
netbird up --allow-server-sshand get a native SSH endpoint without exposing port 22 to the internet. -
Identity-aware access with JWT - SSH sessions are authenticated via your IdP (OIDC/JWT) by default, so you know which user accessed which machine.
Works with
netbird sshand OpenSSH - Usenetbird ssh user@<peer-ip>or standardssh,sftp, andscpcommands; NetBird configures OpenSSH automatically via a drop-in99-netbird.conf. -
Port 22, transparently secured - NetBird listens on TCP 22022 and redirects NetBird-network port 22 traffic to it, so existing SSH workflows keep working without changing ports.
Advanced features when you need them - Optional SFTP, local and remote port forwarding, root login, and JWT token caching (
--ssh-jwt-cache-ttl) for fewer auth prompts. -
Machine identity mode (legacy behavior) - Prefer host-based trust? Disable JWT auth with
--disable-ssh-authand rely purely on network-level ACLs.
How it works
- Enable the SSH server on the target peer
netbird down # if already running
Add optional flags for SFTP, port forwarding, or root login as needed:
netbird up --allow-server-ssh \
--enable-ssh-local-port-forwarding \
--enable-ssh-remote-port-forwarding \
--enable-ssh-sftp \
--enable-ssh-root
Create an ACL policy for SSH
Allow TCP port 22022 from your SSH client peers/groups to your SSH server peers/groups in Access Control. -
Enable SSH in the Dashboard
Open the target peer → enable SSH Access. -
Connect via CLI or OpenSSH
- NetBird CLI:
netbird ssh user@100.119.230.104
- OpenSSH:
sftp user@100.119.230.104
scp file.txt user@100.119.230.104:/path
Read more in the SSH documentation: SSH Access - NetBird Docs
Client Improvements
Updated the client login success page with an improved user experience.
#4797 -
Reverted deprecated gRPC client code migration to restore expected behavior.
#4805
Management Improvements
- Fixed handling of port ranges in route firewall rules to ensure accurate rule application.
#4801
Upgrade & Compatibility Notes
NetBird SSH in v0.60.0 is a breaking change:- Server port changed from 44338 → 22022
- Authentication moved from machine public keys to JWT-based user identity
- Implicit firewall rules were removed - you now need an explicit ACL for port 22022
Version compatibility: v0.60.0+ SSH is not backward compatible with older peers.
For self-hosted environments, we recommend updating in this order:- Management server
- Dashboard (for browser SSH, if used)
- SSH servers first (peers with
--allow-server-ssh) - SSH clients last (
netbird sshusers)
Full Changelog**: v0.59.13…v0.60.0
