- [management] activity events on group updates by @pascal-fischer in https://github.com/netbirdio/netbird/pull/4750
- Bump github.com/containerd/containerd from 1.7.27 to 1.7.29 by @dependabot[bot] in https://github.com/netbirdio/netbird/pull/4756
- [management] incremental network map builder by @crn4 in https://github.com/netbirdio/netbird/pull/4753
- [management] add pat rate limiting by @pascal-fischer in https://github.com/netbirdio/netbird/pull/4741
- [management] remove toAll firewall rule by @crn4 in https://github.com/netbirdio/netbird/pull/4725
- [management] remove GLOBAL when disabling foreign keys on mysql by @pascal-fischer in https://github.com/netbirdio/netbird/pull/4615
- [management ] remove timing logs by @pascal-fischer in https://github.com/netbirdio/netbird/pull/4761
- [client] Create networkd.conf.d if it doesn’t exist by @lixmal in https://github.com/netbirdio/netbird/pull/4764
- [management] fix pg db deadlock after app panic by @crn4 in https://github.com/netbirdio/netbird/pull/4772
- [client] Fix agent reference by @pappz in https://github.com/netbirdio/netbird/pull/4776
- [management] move network map logic into new design by @pascal-fischer in https://github.com/netbirdio/netbird/pull/4774
- [management] Removed policy posture checks on original peer by @pascal-fischer in https://github.com/netbirdio/netbird/pull/4779
- [client] Fix shutdown blocking on stuck ICE agent close by @lixmal in https://github.com/netbirdio/netbird/pull/4780
- [client] Add quick actions window by @doromaraujo in https://github.com/netbirdio/netbird/pull/4717
- [client] Use stdnet with a context to avoid DNS deadlocks by @lixmal in https://github.com/netbirdio/netbird/pull/4781
- [client] Replace ipset lib by @lixmal in https://github.com/netbirdio/netbird/pull/4777
Full Changelog: https://github.com/netbirdio/netbird/compare/v0.59.12...v0.59.13
