- Improve wording in the NetBird client app by @braginini in Improve wording in the NetBird client app by braginini · Pull Request #4316 · netbirdio/netbird · GitHub
- [server] Add MySQL initialization script and update Docker configuration by @pappz in [server] Add MySQL initialization script and update Docker configuration by pappz · Pull Request #4345 · netbirdio/netbird · GitHub
- [management] Use DI containers for server bootstrapping by @pascal-fischer in [management] Use DI containers for server bootstrapping by pascal-fischer · Pull Request #4343 · netbirdio/netbird · GitHub
- [management] fail on geo location init failure by @pascal-fischer in [management] fail on geo location init failure by pascal-fischer · Pull Request #4362 · netbirdio/netbird · GitHub
- [client] Fix rule order for deny rules in peer ACLs by @lixmal in [client] Fix rule order for deny rules in peer ACLs by lixmal · Pull Request #4147 · netbirdio/netbird · GitHub
- [management] Remove save account calls by @pascal-fischer in [management] Remove save account calls by pascal-fischer · Pull Request #4349 · netbirdio/netbird · GitHub
- [client] Fix/ice handshake by @pappz in https://github.com/netbirdio/netbird/pull/4281
- Bump GitHub - containerd/containerd: An open and reliable container runtime · GitHub from 1.7.16 to 1.7.27 by @dependabot[bot] in Bump github.com/containerd/containerd from 1.7.16 to 1.7.27 by dependabot[bot] · Pull Request #3527 · netbirdio/netbird · GitHub
- [management] add nil handling for route domains by @pascal-fischer in [management] add nil handling for route domains by pascal-fischer · Pull Request #4366 · netbirdio/netbird · GitHub
- [management] Add CreatedAt field to Peer and model by @hakansa in [management] Add CreatedAt field to Peer and model by hakansa · Pull Request #4371 · netbirdio/netbird · GitHub
- Bump The Go Programming Language from 0.24.0 to 0.27.0 by @dependabot[bot] in Bump golang.org/x/oauth2 from 0.24.0 to 0.27.0 by dependabot[bot] · Pull Request #4176 · netbirdio/netbird · GitHub
- [management,client] Feat/exit node auto apply by @hakansa in https://github.com/netbirdio/netbird/pull/4272
- feat(doc): Fix confusing comment by @Sonlis in feat(doc): Fix confusing comment by Sonlis · Pull Request #4376 · netbirdio/netbird · GitHub
- refactor doc workflow by @hakansa in refactor doc workflow by hakansa · Pull Request #4373 · netbirdio/netbird · GitHub
- @Sonlis made their first contribution in feat(doc): Fix confusing comment by Sonlis · Pull Request #4376 · netbirdio/netbird · GitHub
Full Changelog: Comparing v0.54.2...v0.55.0 · netbirdio/netbird · GitHub
