@Releases
This version introduces support for relaying disconnection indications from the relay server. With this change, relayed disconnects are detected early, and the clients should start renegotiation.
This change requires a relay update to support new clients fully; otherwise, they will retry connections to old relays and fallback to Coturn-based relay connections.
Whatβs Changed
π»] avoid parsing NB_NETSTACK_SKIP_PROXY if empty by@iisteevin #4145 - [client, relay-server] Feature/relay notification by
@pappzin #4083 - [
v0.51.1] [π»] Fix/nil relayed address by@pappzin #4153
Full Changelog: v0.50.0...v0.51.1
Get it now!
https://github.com/netbirdio/netbird/releases/tag/v0.51.1
