Netbird selfhosted - no setup page at first login
**Hi!
I’m a newbie trying to get Netbird up and running. While doing so I misconfigured it - as I don’t know where and when I started the installation by docker-container again.
I stopped all runnning containers and moved them to another folder to save them. I deleted all containers also (docker container prune -f).
Using the netbird-installation-script was successful but I cannot get to the first setup-page. The page is showing the two ‘old’ login-options** #1 email #2 authentik. There is no option to create the first user.
As this is a new installation there is no user etc.
Where do I have to delete ‘old’ configurations? As the the old netbird installation isn’t running and the folder (docker compose files) is within another path is there a configuration outside the docker-container I have to delete?
Kind regards,
Tom
Problem solved - had to reboot the vps…
