Just a rehash of Peer connection details show Docker gateway IP 172.30.0.1 as public IP when peer connects via IPv6 - #10 by netsrot303
The “solution” was to just remove the AAAA record and use IPv4 only basically.
Actual working solution for those who want to use IPv6
Backup your files, I’m not responsible if this breaks anything.
Create /opt/netbird/docker-compose.override.yml
2a. Enable ipv6 and give traefik a static ipv6 address. My override for reference.
services:
traefik:
networks:
netbird:
ipv6_address: "fd01:aaaa:aaaa:0201::10"
networks:
netbird:
enable_ipv6: true
ipam:
config: !override
- subnet: "172.30.0.0/24"
gateway: "172.30.0.1"
- subnet: "fd01:aaaa:aaaa:0201::/64"
gateway: "fd01:aaaa:aaaa:0201::1"
ip_range: "fd01:aaaa:aaaa:0201:8000::/65"
- Edit /opt/netbird/config.yaml to add your IPv6 address to trustedHTTPProxies.
reverseProxy:
trustedHTTPProxies:
- "172.30.0.10/32"
- "fd01:aaaa:aaaa:0201::10/128"
- Edit /opt/netbird/proxy.env adding your IPv6 address to NB_PROXY_TRUSTED_PROXIES
NB_PROXY_TRUSTED_PROXIES=172.30.0.10,fd01:aaaa:aaaa:0201::10/128
