Trying to run “netbird up --setup-key XXXX”. The command starts but then does nothing. No movement whatsoever. No timeout. I tried restarting the UDM, but still same issue.
- Install Netbird on UDM
- Run “netbird up --setup-key XXXXX”
- Nothing happens
A clear and concise description of what you expected to happen.
Yes
Yes, Wireguard using Unifi built-in client. I disabled this but there was no change.
[INFO] SYSTEM (8663c2e9-34ff-4ec0-8d27-0490503decd3)
Message: daemon config changed (source=startup)
Time: 12 minutes, 50 seconds ago
Metadata: source: startup, type: config_changed
OS: linux/arm64
Daemon version: 0.83.1
CLI version: 0.83.1
Management: Disconnected, reason: rpc error: code = FailedPrecondition desc = failed connecting to Management Service : create connection: dial context: context deadline exceeded
Signal: Disconnected
FQDN:
NetBird IP: N/A
Interface type: N/A
Wireguard port: N/A
Lazy connection: false
Peers count: 0/0 Connected
netbird debug for 1m -AS -U
e25964769d28a391f71decfec4ca9c888c4cf40b8cbeeb9369abf0930848ca44/62d6deaa-4bed-4f76-abeb-eb5978bb08cf
Uploaded files are automatically deleted after 30 days.
Alternatively, create the file only and attach it here manually:
If applicable, add screenshots to help explain your problem.
This working a couple of weeks ago, but it has been updated and rebooted. I tried uninstalling and reinstalling but nothing works.
- Disabled other VPN software
- Checked firewall settings
