Hi,
I have a home-lab with many server connected with Tailscale/Headscale today. I managed my own DNSmasq config. I want to be able to resolve “serverA.xxx.xxx” to get the private IP of a node. I can do that with Tailscale with MagicDNS
I installed Netbird on my home-lab, composed of many servers
I used the --disable-dns to connect my nodes but it seems that I’m not able to resolve my server name (server1.dns.xxxx.xxxx for example). I think I’m probably doing something wrong so I wanted to ask at the community for help if this is possible.
I did the local config of dnsmasq this way :
server=/dns.xxx.xxx/<Private_IP>:53 # Port used by netbird
I confirm the good port with a netstat -latupon | grep 53, it could be 5053 If i remember well.
When I try to resolve, I got a timeout.
- Install Netbird with
--disable-dns - configure your local resolver to handle the domain “dns.xxx.xxx” and redirect to the local netbird service which is listening in port 53 or 5053
- Try to resolve any node dns with the domain configured on netbird (serverA.dns.xxx.xxx)
I want to be able to resolve localy all the node dns name configured in netbird to avoid using private IP on my services configurations.
No, self-hosted.
Last one (0.66.0)
Yes, Tailscale/Headscale.
I think I’m not understanding something in the documentation which seems to be well done, sorry if my problem is trivial
Thanks for help
