Need your advice according hardware to run netbird
Hi!
I kindly ask for your help as I’m not sure about the hardware or the solution I should use…
I would like to get a netbird gateway in another country up and running where I would like to have my backup-server also. The device cannot be too slow in handling the VPN-connection (>500 Mbit) and it should be equipped with some rj-45 ports (at least 1xWAN, 2xLAN).
At first I was thinking about an GliNet (Brume 3 (GL-MT5000)) just to read that their firmware is outdated and OpenWrt does not support the device right now.
As I do hope that I’m not the first one thinking about this, I would like to know your recommendations. Having Netbird as a need that should be supported without any ‘problems’ I hope to get the best solution with all you netbird-users.
Kind regards,
Tom
