Hello,
I have a Nanopi R3S LTS 2GB as an Openwrt router.
On my main-lan:
I configured Adguard Home and Unbound as my DNS Server. All my traffic exits through a Protonvpn server via Wireguard, port 51820. Ipv6 fully configured.
On my guest-lan:
No AGH, no protonvpn exit. Ipv6 fully configured.
I use PBR for routing traffic from guest-lan through wan, and for something else aswell.
I want to be able to connect to my home network from anywhere with my mobile devices, such that it’s like I’m at home in my main-lan with AGH, proton exit etc. In the past I used a direct wireguard connection with the wireguard app on my mobile devices, but I wanted to switch to netbird because I need the netbird features especially in the future.
Here is my current config, please tell me if you need to see something else:
root@nanopi:~# uci show network
network.loopback=interface
network.loopback.device='lo'
network.loopback.proto='static'
network.loopback.ipaddr='127.0.0.1/8'
network.globals=globals
network.globals.dhcp_default_duid='00047c79411fe9c14cb0807b16885eebad65'
network.globals.ula_prefix='fd39:9497:bd6::/48'
network.globals.packet_steering='1'
network.@device[0]=device
network.@device[0].name='br-lan'
network.@device[0].type='bridge'
network.@device[0].ports='eth1'
network.@device[1]=device
network.@device[1].name='eth1'
network.@device[1].macaddr='f6:44:20:63:01:15'
network.lan=interface
network.lan.device='br-lan'
network.lan.proto='static'
network.lan.ip6assign='64'
network.lan.ipaddr='192.168.10.1'
network.lan.multipath='off'
network.lan.netmask='255.255.255.0'
network.lan.defaultroute='0'
network.lan.delegate='0'
network.@device[2]=device
network.@device[2].name='eth0'
network.@device[2].macaddr='f6:44:20:63:01:14'
network.wan=interface
network.wan.device='eth0'
network.wan.proto='pppoe'
network.wan.username='...'
network.wan.password='...'
network.wan.ipv6='0'
network.wan.multipath='off'
network.wan.peerdns='0'
network.wan.delegate='0'
network.wan.sourcefilter='0'
network.wan.force_link='1'
network.wan6=interface
network.wan6.device='@wan'
network.wan6.proto='dhcpv6'
network.wan6.reqaddress='try'
network.wan6.reqprefix='auto'
network.wan6.norelease='1'
network.wan6.multipath='off'
network.wan6.peerdns='0'
network.wan6.force_link='1'
network.lan_guest=interface
network.lan_guest.proto='static'
network.lan_guest.device='eth1.2'
network.lan_guest.ipaddr='192.168.20.1'
network.lan_guest.netmask='255.255.255.0'
network.lan_guest.defaultroute='0'
network.lan_guest.multipath='off'
network.lan_guest.delegate='0'
network.lan_guest.ip6assign='64'
network.@wireguard_protonvpn[0]=wireguard_protonvpn
network.@wireguard_protonvpn[0].public_key='tBLnlY4CJsNGmh6qbDZTAogZZ+jIOvt4b2mCA8i97U4='
network.@wireguard_protonvpn[0].persistent_keepalive='25'
network.@wireguard_protonvpn[0].endpoint_host='2a02:6ea0:1703:3087::10'
network.@wireguard_protonvpn[0].endpoint_port='51820'
network.@wireguard_protonvpn[0].route_allowed_ips='1'
network.@wireguard_protonvpn[0].allowed_ips='::/0' '0.0.0.0/0' '::/1' '8000::/1'
network.@device[3]=device
network.@device[3].name='pppoe-wan'
network.@device[4]=device
network.@device[4].name='eth1.2'
network.@device[4].type='8021q'
network.@device[4].ifname='eth1'
network.@device[4].vid='2'
network.@device[4].macaddr='02:1A:2B:3C:4D:5E'
network.protonvpn=interface
network.protonvpn.proto='wireguard'
network.protonvpn.force_link='1'
network.protonvpn.private_key='...'
network.protonvpn.addresses='2a07:b944::2:2/128' '10.2.0.2/32'
network.protonvpn.multipath='off'
network.protonvpn.delegate='0'
network.protonvpn.mtu='1420'
network.@device[5]=device
network.@device[5].name='protonvpn'
network.@wireguard_homevpn[0]=wireguard_homevpn
network.@wireguard_homevpn[0].description='iPad'
network.@wireguard_homevpn[0].public_key='umiA/e8eyJq5eNP1PHs+BUOtu2u1MQcQuDMtJI+saD8='
network.@wireguard_homevpn[0].route_allowed_ips='1'
network.@wireguard_homevpn[0].persistent_keepalive='25'
network.@wireguard_homevpn[0].allowed_ips='fd10:10:10::3/128' '10.10.10.3/32'
network.@wireguard_homevpn[1]=wireguard_homevpn
network.@wireguard_homevpn[1].public_key='h8ovJJMP+7p74kOB41WnCDVspHf9YJl79VE+ObouaSk='
network.@wireguard_homevpn[1].route_allowed_ips='1'
network.@wireguard_homevpn[1].persistent_keepalive='25'
network.@wireguard_homevpn[1].description='iPhone'
network.@wireguard_homevpn[1].allowed_ips='fd10:10:10::2/128' '10.10.10.2/32'
network.netbird=interface
network.netbird.proto='none'
network.netbird.device='wt0'
network.netbird.defaultroute='0'
network.netbird.multipath='off'
network.netbird.delegate='0'
network.@device[6]=device
network.@device[6].name='wt0'
root@nanopi:~# uci show firewall
firewall.@defaults[0]=defaults
firewall.@defaults[0].input='REJECT'
firewall.@defaults[0].output='ACCEPT'
firewall.@defaults[0].forward='REJECT'
firewall.@defaults[0].synflood_protect='1'
firewall.@zone[0]=zone
firewall.@zone[0].name='lan'
firewall.@zone[0].input='ACCEPT'
firewall.@zone[0].output='ACCEPT'
firewall.@zone[0].forward='ACCEPT'
firewall.@zone[0].network='lan'
firewall.@zone[1]=zone
firewall.@zone[1].name='wan'
firewall.@zone[1].input='REJECT'
firewall.@zone[1].output='ACCEPT'
firewall.@zone[1].forward='REJECT'
firewall.@zone[1].masq='1'
firewall.@zone[1].mtu_fix='1'
firewall.@zone[1].network='wan' 'wan6'
firewall.@rule[0]=rule
firewall.@rule[0].name='Allow-DHCP-Renew'
firewall.@rule[0].src='wan'
firewall.@rule[0].proto='udp'
firewall.@rule[0].dest_port='68'
firewall.@rule[0].target='ACCEPT'
firewall.@rule[0].family='ipv4'
firewall.@rule[0].enabled='1'
firewall.@rule[1]=rule
firewall.@rule[1].name='Allow-Ping'
firewall.@rule[1].src='wan'
firewall.@rule[1].proto='icmp'
firewall.@rule[1].icmp_type='echo-request'
firewall.@rule[1].family='ipv4'
firewall.@rule[1].target='ACCEPT'
firewall.@rule[1].enabled='1'
firewall.@rule[2]=rule
firewall.@rule[2].name='Allow-IGMP'
firewall.@rule[2].src='wan'
firewall.@rule[2].proto='igmp'
firewall.@rule[2].family='ipv4'
firewall.@rule[2].target='ACCEPT'
firewall.@rule[2].enabled='1'
firewall.@rule[3]=rule
firewall.@rule[3].name='Allow-DHCPv6'
firewall.@rule[3].src='wan'
firewall.@rule[3].proto='udp'
firewall.@rule[3].dest_port='546'
firewall.@rule[3].family='ipv6'
firewall.@rule[3].target='ACCEPT'
firewall.@rule[3].enabled='1'
firewall.@rule[4]=rule
firewall.@rule[4].name='Allow-MLD'
firewall.@rule[4].src='wan'
firewall.@rule[4].proto='icmp'
firewall.@rule[4].src_ip='fe80::/10'
firewall.@rule[4].icmp_type='130/0' '131/0' '132/0' '143/0'
firewall.@rule[4].family='ipv6'
firewall.@rule[4].target='ACCEPT'
firewall.@rule[4].enabled='1'
firewall.@rule[5]=rule
firewall.@rule[5].name='Allow-ICMPv6-Input'
firewall.@rule[5].src='wan'
firewall.@rule[5].proto='icmp'
firewall.@rule[5].icmp_type='echo-request' 'echo-reply' 'destination-unreachable' 'packet-too-big' 'time-exceeded' 'bad-header' 'unknown-header-type' 'router-solicitation' 'neighbour-solicitation' 'router-advertisement' 'neighbour-advertisement'
firewall.@rule[5].limit='1000/sec'
firewall.@rule[5].family='ipv6'
firewall.@rule[5].target='ACCEPT'
firewall.@rule[5].enabled='1'
firewall.@rule[6]=rule
firewall.@rule[6].name='Allow-ICMPv6-Forward'
firewall.@rule[6].src='wan'
firewall.@rule[6].dest='*'
firewall.@rule[6].proto='icmp'
firewall.@rule[6].icmp_type='echo-request' 'echo-reply' 'destination-unreachable' 'packet-too-big' 'time-exceeded' 'bad-header' 'unknown-header-type'
firewall.@rule[6].limit='1000/sec'
firewall.@rule[6].family='ipv6'
firewall.@rule[6].target='ACCEPT'
firewall.@rule[6].enabled='1'
firewall.@rule[7]=rule
firewall.@rule[7].name='Allow-IPSec-ESP'
firewall.@rule[7].src='wan'
firewall.@rule[7].dest='lan'
firewall.@rule[7].proto='esp'
firewall.@rule[7].target='ACCEPT'
firewall.@rule[7].enabled='1'
firewall.@rule[8]=rule
firewall.@rule[8].name='Allow-ISAKMP'
firewall.@rule[8].src='wan'
firewall.@rule[8].dest='lan'
firewall.@rule[8].dest_port='500'
firewall.@rule[8].proto='udp'
firewall.@rule[8].target='ACCEPT'
firewall.@rule[8].enabled='1'
firewall.@zone[2]=zone
firewall.@zone[2].name='lan_guest'
firewall.@zone[2].input='REJECT'
firewall.@zone[2].output='ACCEPT'
firewall.@zone[2].forward='REJECT'
firewall.@zone[2].network='lan_guest'
firewall.@forwarding[0]=forwarding
firewall.@forwarding[0].src='lan_guest'
firewall.@forwarding[0].dest='wan'
firewall.@rule[9]=rule
firewall.@rule[9].name='Allow-DHCP-Guest'
firewall.@rule[9].src='lan_guest'
firewall.@rule[9].proto='udp'
firewall.@rule[9].dest_port='67'
firewall.@rule[9].target='ACCEPT'
firewall.@rule[9].enabled='1'
firewall.@rule[10]=rule
firewall.@rule[10].name='Allow-ICMPv6-Guest'
firewall.@rule[10].src='lan_guest'
firewall.@rule[10].proto='icmp'
firewall.@rule[10].family='ipv6'
firewall.@rule[10].target='ACCEPT'
firewall.@rule[10].icmp_type='bad-header' 'destination-unreachable' 'neighbour-advertisement' 'neighbour-solicitation' 'packet-too-big' 'router-advertisement' 'router-solicitation' 'time-exceeded' 'unknown-header-type'
firewall.@rule[10].enabled='1'
firewall.@rule[11]=rule
firewall.@rule[11].name='Allow-DHCPv6-Guest'
firewall.@rule[11].src='lan_guest'
firewall.@rule[11].proto='udp'
firewall.@rule[11].dest_port='547'
firewall.@rule[11].target='ACCEPT'
firewall.@rule[11].enabled='1'
firewall.@zone[3]=zone
firewall.@zone[3].name='protonvpn'
firewall.@zone[3].input='REJECT'
firewall.@zone[3].output='ACCEPT'
firewall.@zone[3].forward='REJECT'
firewall.@zone[3].masq='1'
firewall.@zone[3].mtu_fix='1'
firewall.@zone[3].masq6='1'
firewall.@zone[3].network='protonvpn'
firewall.@forwarding[1]=forwarding
firewall.@forwarding[1].src='lan'
firewall.@forwarding[1].dest='protonvpn'
firewall.@rule[12]=rule
firewall.@rule[12].src='lan'
firewall.@rule[12].dest='wan'
firewall.@rule[12].name='Allow-fritzbox'
firewall.@rule[12].target='ACCEPT'
firewall.@rule[12].enabled='1'
firewall.@rule[12].src_ip='192.168.10.10'
firewall.@rule[12].family='ipv4'
firewall.@rule[12].proto='all'
firewall.@zone[4]=zone
firewall.@zone[4].name='netbird'
firewall.@zone[4].input='ACCEPT'
firewall.@zone[4].output='ACCEPT'
firewall.@zone[4].forward='ACCEPT'
firewall.@zone[4].network='netbird'
firewall.@zone[4].mtu_fix='1'
firewall.@zone[4].masq='1'
firewall.@zone[4].masq6='1'
firewall.@forwarding[2]=forwarding
firewall.@forwarding[2].src='netbird'
firewall.@forwarding[2].dest='lan'
firewall.@forwarding[3]=forwarding
firewall.@forwarding[3].src='lan'
firewall.@forwarding[3].dest='netbird'
pbr config:
config pbr 'config'
option fw_mask 'ff000000'
option uplink_mark '01000000'
option uplink_ip_rules_priority '30000'
option uplink_interface 'wan'
option uplink_interface6 'wan6'
config policy
option name 'Gastnetz wan'
option src_addr '@eth1.2'
option interface 'wan'
config policy
option name 'Festnetz wan'
option src_addr '192.168.10.10/32'
ip rule:
0: from all lookup local
105: from all lookup main suppress_prefixlength 0
110: not from all fwmark 0x1bd00 lookup netbird
29997: from all lookup main suppress_prefixlength 1
29998: from all fwmark 0x3000000/0xff000000 lookup pbr_netbird
29999: from all fwmark 0x2000000/0xff000000 lookup pbr_protonvpn
30000: from all fwmark 0x1000000/0xff000000 lookup pbr_wan
32766: from all lookup main
ip route table netbird:
$ ip route show table netbird
Error: ipv4: FIB table does not exist.
$ ip -6 route show table netbird
(empty)
Netbird nftables:
chain netbird-mangle-prerouting {
iifname != "wt0" ct state new meta mark set 0x0001bd22
iifname "wt0" ct state new meta mark set 0x0001bd21
chain netbird-rt-postrouting {
meta mark 0x0001bd21 oifname != "lo" masquerade
meta mark 0x0001bd22 oifname "wt0" masquerade
pbr Marking-Chains:
chain pbr_prerouting {
meta mark & 0xff000000 != 0x00000000 return
iifname "eth1.2" goto pbr_mark_0x1000000 # Gastnetz wan
ip saddr 192.168.10.10 goto pbr_mark_0x1000000 # Festnetz wan
Netbird status:
root@nanopi:~# netbird status -d
laptop.netbird.cloud:
NetBird IP: 100.114.2.124
NetBird IPv6: fd72:d03:c98c:d80f:b70a:b9fa:4bb4:fca3
Public key: iRBjgwUShGfFu0CS//OadnbliWDrwFl6w3xSfIGADn8=
Status: Connecting
Connection type: -
Relay server address:
Last connection update: 1 hour, 36 minutes ago
Last WireGuard handshake: -
iphone.netbird.cloud:
NetBird IP: 100.114.199.211
NetBird IPv6: fd72:d03:c98c:d80f:1741:d463:3e4d:7803
Public key: cLQ6rbKZqR+lM/k2nPWCk5jA2opLkizILOD4kgT9yDw=
Status: Connecting
Connection type: -
Last connection update: 59 minutes, 10 seconds ago
ipad.netbird.cloud:
NetBird IP: 100.114.244.103
NetBird IPv6: fd72:d03:c98c:d80f:9b77:3e69:da17:fb05
Public key: HmPwRV93qWe1mk1FwuzrYxtjaSqd+cFrxpWApGNXVlE=
Status: Idle
Connection type: -
Last connection update: -
[INFO] SYSTEM (4f3e7de4-06ba-433e-aa1c-03aa1329d9dc)
Time: 17 hours, 17 minutes ago
[INFO] SYSTEM (5aed9101-fd4b-4927-9d4e-979d487d4dff)
Message: daemon config changed (source=up_rpc)
Metadata: source: up_rpc, type: config_changed
[INFO] SYSTEM (f3afe867-db2d-47e5-9586-8bd4ad71d5d4)
[INFO] SYSTEM (8a7d9f83-cfb6-4ac8-91f6-39306244c0b6)
Time: 5 hours, 59 minutes ago
[INFO] SYSTEM (12932bd3-417f-4c7f-b6bc-117b18e42711)
Time: 5 hours, 55 minutes ago
[INFO] SYSTEM (d7f14b8e-e9fd-40e2-b928-eadb73cb4e8f)
Time: 5 hours, 21 minutes ago
[INFO] SYSTEM (3967dc4f-21e4-4556-98c1-44ff6e03877e)
[INFO] SYSTEM (986a028f-d941-4522-9a16-7529b0390cb4)
Time: 2 hours, 57 minutes ago
[INFO] SYSTEM (ea392658-de42-45bf-bfe6-ccbda2401e04)
Time: 2 hours, 38 minutes ago
[INFO] SYSTEM (5f0f2de7-6cf4-4caf-bb9d-b33ded83f839)
Time: 14 minutes, 58 seconds ago
OS: linux/arm64
Daemon version: 0.73.2
CLI version: 0.73.2
Management: Connected to https://api.netbird.io:443
Signal: Connected to https://signal.netbird.io:443
[stun:stun.netbird.io:443] is Available
[stun:stun.netbird.io:5555] is Available
[turns:turn.netbird.io:443?transport=tcp] is Available
[rels://streamline-de-fra1-7.relay.netbird.io:443] is Available via ws
FQDN: nanopi.netbird.cloud
NetBird IP: 100.114.9.95/16
NetBird IPv6: fd72:d03:c98c:d80f:7e8e:a5d1:f7ff:9818/64
Interface type: Kernel
Wireguard port: 51820
Lazy connection: true
Networks: 0.0.0.0/0, ::/0
Peers count: 0/3 Connected
I set up netbird on my router just like the netbird doc suggested. I didn’t do the following step, because I believe I don’t need to:
DNS configuration
OpenWrt runs dnsmasq on port 53, which conflicts with NetBird’s managed DNS. To use NetBird DNS features such as domain resources and peer name resolution, run NetBird’s resolver on an alternative port and forward NetBird domains to it through dnsmasq.
Set a custom DNS resolver address
When port 53 is taken, NetBird automatically falls back to an
alternative port, but pinning the address keeps the dnsmasq forwarding
rule below valid:netbird up --dns-resolver-address 127.0.0.1:5053 -
Forward NetBird domains in dnsmasq
Add a server entry to
/etc/config/dhcpunder thednsmasqsection, replacingnetbird.cloudwithnetbird.selfhostedor your custom DNS domain if you are self-hosting:uci add_list dhcp.@dnsmasq[0].server='/netbird.cloud/127.0.0.1#5053' uci commit dhcp /etc/init.d/dnsmasq restart
So in the netbird webinterface, I did the following:
I added my router and my mobile devices as peers.
I have a policy with source being a group with my mobile devices, direction only to the destination, which is the peer “router”. Proto&ports: all.
I set up my router as exit node with type routing peer. Distribution group is the mobile group, auto apply is checked.
I set up a DNS Nameserver with the Ipv4 of my router, port 53, match domain all. Groups: mobile.
In the settings, mobile group is Ipv6 enabled.
So at first I wasn’t able to connect to my home network from my cellular network for example. So because I am somewhat of a beginner, I used Claude to troubleshoot, and Claude told me that something with fmark from PBR was conflicting with fmark from netbird… Claude was confident so I changed some value in a PBR config file (see above). Then I also noticed a mistake I did in the netbird webinterface, and then it worked, so I don’t really know if it was necessary what I changed in the config file.
Right now, on my guest-lan, Ipv6 doesn’t seem to work (I’m checking on test-ipv6.com), and the connection to my home network is always relayed and not p2p. Other than that the connection seems to work as expected.
But I’m really sure that this is unstable and not correctly configured… Can you please help me out? Is my firewall correctly configured? Is the port netbird uses the same as the one from protonvpn? Do I need to maybe add a traffic rule? What’s up with the PBR stuff? Why has Ipv6 stopped working on my guest-lan? I don’t trust Claude anymore on this matter, and I can’t find articles on my specific setup…
I really am sorry for the length of this post, also for the grammar, I’m from Germany. On top of that I’m not an expert.
Please help me, I don’t know how to fix this or how to correctly set this up…
