Multicast dns .local workaround
Dns resolution for my internal domain (toto.local)
After setup netbird self hosted with docker container, i test all my needs
ping differents networks from peer through netbird client peer docker (because i want to access to networks behind router) → test ok for all
after that, i test dns resolution wit my domain toto.local and it’s not ok because netbird block multicast resolution (.local), all is ok with toto**.lan**
ping mymachine.toto.local ok
No sel hosted on ubuntu machine with docker container and traefik v3
netbird version 0.77
no
netbird status -dA
vmpnet01pa03.anon-2T4U2.domain:
NetBird IP: 100.97.142.160
Public key: VPPZf8Wc6jbGnzGpe3/WVa8qoKN3OurQw+2LNFOP7gE=
– detail –
Connection type: Relayed
Relay server address: rels://zerotrust.anon-PixjB.domain:443
Last connection update: 12 minutes ago
Last WireGuard handshake: 12 seconds ago
Transfer status (received/sent) 106.1 MiB/4.4 MiB
Networks: 10.0.14.0/24, 10.0.20.0/24
[INFO] SYSTEM (ea5dae54-45d0-46e4-b53e-ad3ac6b092d6)
Message: daemon config changed (source=startup)
Time: 12 minutes, 23 seconds ago
Metadata: source: startup, type: config_changed
[INFO] SYSTEM (8363a6c8-6a09-437f-b07d-39c8c752fadc)
Time: 12 minutes ago
[INFO] SYSTEM (41932b49-16eb-4af1-a6d7-f71fcbfb5bbe)
Message: New version available
Time: 10 minutes, 46 seconds ago
Metadata: new_version_available: 0.77.0
[INFO] SYSTEM (d09ae5f7-c483-4b6c-ae7c-47b003c0a673)
Time: 9 minutes ago
[INFO] SYSTEM (0ccfd240-f1ca-4206-9076-08f852edf7ae)
Time: 9 minutes ago
OS: windows/amd64
Daemon version: 0.76.3
CLI version: 0.76.3
Management: Connected to “zerotrust.anon-PixjB.domain:443”
Signal: Connected to “zerotrust.anon-PixjB.domain:443”
[stun:zerotrust.anon-PixjB.domain:3478] is Checking…
[rels://zerotrust.anon-PixjB.domain:443] is Available via ws
[10.0.20.50:53, 10.0.20.51:53] for [prd05.anon-PixjB.domain, anon-2T4U2.domain, local, anon-zWecH.domain, uat.anon-PixjB.domain, anon-6KKHg.domain] is Available
FQDN: test-lp178.anon-2T4U2.domain
NetBird IP: 100.97.214.207/16
Interface type: Userspace
Wireguard port: 51820
Lazy connection: true
Netbird server docker + Netbird docker client : routing peer through netbird docker client peer because routing with router to access to networks (ip forwrd ok on ubuntu machine)
net.ipv4.ip_forward=1
net.ipv4.conf.all.src_valid_mark=1
net.ipv6.conf.all.forwarding=1
I try to setup in docker client
dns:
  • 10.0.20.50
  • 10.0.20.51
    extra_hosts:
  • “toto.local:10.0.20.50”
i add “local”,“toto.local” in dns managemnet settings in ui but not ok
toto**.lan** ok
ok sorry, after so many search and debug, solution is simple
go to settings, remove in networks dns domains all suffixe
Specify a custom peer DNS domain for your network. This should not point to a valid domain to avoid overriding DNS results. → NONE (empty)
and you can add your toto**.local** suffixe
