Locked out after enabling SSO
I installed Netbird following the assistant, which created a local user. With that user, i enabled our Authentik SSO in the Auth Section. Enabling SSO seems to disable the local admin user, but the Authentik Users dont have permission to enter the Netbird Management yet.
Without explicitly disabling local login, both SSO and local Login should be visible. As is, i am getting forwarded to oauth directly although i never explicitly disabled local login.
current docker imahe
In Nextcloud for example, you can pass ?direct=1 to skip SSO auth. Is there something similar in Netbird?
