LAN Access to Remote Access NetBird Client
Netbird 0.79 Self hosted running on Ubuntu 24 LTS.
Routing peer configured and working.
Remote Netbird clients can connect using local IDP and access local LAN resources in the 10.20.2.0/24 subnet with no issues. Netbird clients use a specific IP subnet range (10.20.255.0/24). Masquerading is disabled on the routing peer.
However devices on the LAN behind the routing-peer cannot initiate a connection back to a remote Netbird client. I have access policies in place that allow ANY ANY in both directions. I understand this is a relatively rare topology however is used in some point cases (like IP Softphones running remotely).
10.20.255.0/24 to 10.20.2.0/24 work fine (Netbird to LAN via routing-peer)
10.20.2.0/24 to 10.20.255.0/24 doesn’t work.
Firewalls (windows in this instance) is disabled on the remote client.
Any connected Netbird client.
Local LAN devices (without Netbird client installed) can initiate connections to remote clients.
Self Host.
0.80 on client
No.
Will upload manually.
File key: de51225ccc6a0d6e3ee7aaf08763dbfd4f198a76a00687e51f130458a30a3a18/2de7e593-3e52-4642-bbde-f991a0a3d894
Alternatively, create the file only and attach it here manually:
netbird debug for 1m -AS
I can see the issue in a netbird debug capture on the client and the client is rejecting packets as they isn’t a policy allowing it. However, I have a bidirectional access policy in place for ALL<>ALL. I can see the message in the local client log file “Dropping local packet (ACL Denied)”
The routing peer (which has an IP address in the same subnet as the client, CAN connect to the remote device.
The client has none of the firewall check boxes enabled (block inbound traffic etc is not enabled)
routing-peer.netbird.selfhosted:
NetBird IP: 10.20.255.58
NetBird IPv6: 2001:db8:ffff::
Public key: GyD1Ef9la0fk7yDi3n/meZnvyd1oOUbZSMPuiFAYxj4=
– detail –
Connection type: P2P
ICE candidate (Local/Remote): host/prflx
ICE candidate endpoints (Local/Remote): 10.1.201.96:51820/10.20.1.100:51820
Relay server address: rels://netbird.anon-ySO9G.domain:443
Last connection update: 16 minutes, 51 seconds ago
Last WireGuard handshake: 1 second ago
Transfer status (received/sent) 4.1 KiB/4.5 KiB
Networks: 10.11.4.0/24, 10.20.1.0/24, 10.20.2.0/24
Latency: 37.3215ms
lynx.netbird.selfhosted:
NetBird IP: 10.20.255.105
NetBird IPv6: 2001:db8:ffff::1
Public key: c43+iHeBjk4kiqNBq33NGs/+kgxVQM6FazRh3EmqbRM=
Status: Idle
– detail –
Connection type: -
Last connection update: -
Last WireGuard handshake: -
sdavies11.netbird.selfhosted:
NetBird IP: 10.20.255.176
NetBird IPv6: 2001:db8:ffff::2
Public key: CN2ZX9ulrxfTZAf8o2YFW9wQ0cAiF0w87F3BxsHVXVY=
Status: Idle
– detail –
Connection type: -
[INFO] SYSTEM (c39b5190-058f-4dfb-be6b-4d616232ad0e)
Message: daemon config changed (source=up_rpc)
Time: 26 minutes, 51 seconds ago
Metadata: source: up_rpc, type: config_changed
[INFO] SYSTEM (05123837-db3c-4292-80fa-eeeb83728e84)
Time: 26 minutes, 49 seconds ago
[INFO] SYSTEM (408b172d-c539-4c6c-b32b-c916a395e434)
Time: 21 minutes, 29 seconds ago
[INFO] SYSTEM (9c07a000-b84d-4a72-b78b-309baadfae1c)
Time: 21 minutes, 16 seconds ago
[INFO] SYSTEM (775ec4a8-9925-40df-bf17-85bfa0e77dda)
Time: 20 minutes, 14 seconds ago
[INFO] SYSTEM (ba13437b-98be-419b-955d-0e5ab3adbbd3)
Time: 20 minutes, 8 seconds ago
[INFO] SYSTEM (3ebefb9f-5f39-491f-aa81-0be678e7af02)
Time: 16 minutes, 55 seconds ago
[INFO] SYSTEM (0ba613e5-e95b-474e-8d5a-361b787ede70)
Time: 16 minutes, 52 seconds ago
OS: windows/amd64
Daemon version: 0.80.0
CLI version: 0.80.0
Profile: BETALENT
Management: Connected to https://netbird.anon-ySO9G.domain:443
Signal: Connected to https://netbird.anon-ySO9G.domain:443
[stun:netbird.anon-ySO9G.domain:3478] is Available
[rels://netbird.anon-ySO9G.domain:443] is Available via ws
[10.20.2.103:53, 10.20.2.113:53] for [anon-tQBev.domain] is Available
FQDN: desktop-2lovhca.netbird.selfhosted
NetBird IP: 10.20.255.165/24
NetBird IPv6: 2001:db8:ffff::3/64
Interface type: Userspace
Wireguard port: 51820
Lazy connection: true
Session expires: 2026-10-08T09:13:58Z (in 21h 53m)
Peers count: 1/3 Connected
2026-10-07T12:26:38+01:00 TRAC Dropping local packet (ACL denied): rule_id= proto=ICMP src=10.20.2.103:0 dst=10.20.255.165:0
2026-10-07T12:26:39+01:00 TRAC Dropping local packet (ACL denied): rule_id= proto=ICMP src=10.20.2.103:0 dst=10.20.255.165:0
2026-10-07T12:26:40+01:00 TRAC Dropping local packet (ACL denied): rule_id= proto=ICMP src=10.20.2.103:0 dst=10.20.255.165:0
Resolved this (at least initially) by running netbird up --disable-firewall.
Slightly odd in that Windows firewall is specifically disabled on the devices that were unreachable from the LAN. However as soon as used the --disable-firewall flag, everything worked.
