iOS client issue
After connecting, it takes a few minutes to use and often disconnects
  1. Open Netbird
  2. Click on ‘connect’
  3. show on
  4. Can not use network
  5. waiting for 1 or 2 minutes is ok
  6. Then down
Once connected, it can be used immediately
No. I’m using self-host
NO
In fact, besides the iOS client, Android clients also have similar problems. The previous version of iOS 3.3 was good, at least more stable than the current version 0.4.1, and the same goes for Windows clients. If it lasts for more than 5 minutes and is not applicable, even if the connection is displayed, the actual network is also unusable
  • [Yes] Reviewed client troubleshooting (if applicable)
  • [Yes] Checked for newer NetBird versions
  • [Yes] Searched for similar issues on GitHub (including closed ones)
  • [Yes] Restarted the NetBird client
  • [Yes] Checked firewall settings
See if you can make any logs that we can use to determine why it’s taking so long.
Ok.Let me try to get some log
Summary
This text will be hidden
Can you help to tell me how to get the log from iOS and Windows?
6a0cf08a5b39ff6a58d76cc9bf2504d9614a9186e848f8bc382bc6a46d592467/559e6882-712e-470f-918a-e9cb1e6dbf57
By the way. When my iphone connect the Netbird, I can not open chatgpt.com. But my MacBook can. Could it be a problem caused by IPv6 on the iPhone?
