Installation Script Failing when selecting Traefik
created new VPS
updated VPS
ran install script from netbird site and selected traefik for reverse proxy
Selfhosted
latest
no
Waiting for Management server to become ready . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Taking too long. Checking logs…
netbird-management | 2026-01-17T15:36:57Z INFO management/server/migration/migration.go:424: executing index creation: CREATE UNIQUE INDEX IF NOT EXISTS idx_peers_key_unique ON peers (key)
netbird-management | 2026-01-17T15:36:57Z INFO management/server/migration/migration.go:429: successfully created index idx_peers_key_unique on table peers
netbird-management | 2026-01-17T15:36:57Z INFO management/server/geolocation/database.go:34: Geolocation database file GeoLite2-City_20251217.mmdb not found, file will be downloaded
netbird-management | 2026-01-17T15:37:02Z INFO management/server/geolocation/database.go:34: Geolocation database file geonames_20251217.db not found, file will be downloaded
netbird-management | 2026-01-17T15:37:12Z INFO management/internals/server/modules.go:45: geolocation service has been initialized from /var/lib/netbird/
netbird-management | 2026-01-17T15:37:12Z INFO management/server/telemetry/app_metrics.go:193: enabled application metrics and exposing on 0.0.0.0:9090
netbird-management | 2026-01-17T15:37:12Z WARN management/internals/server/boot.go:108: TrustedPeers are configured to default value ‘0.0.0.0/0’, ‘::/0’. This allows connection IP spoofing.
netbird-management | 2026-01-17T15:37:12Z INFO management/server/account_request_buffer.go:45: set account request buffer interval to 100ms
netbird-management | 2026-01-17T15:37:12Z INFO management/server/activity/store/sql_store.go:261: using sqlite as activity event store engine
netbird-management | 2026-01-17T15:37:12Z INFO management/server/activity/store/sql_store.go:290: Set max open db connections to 1, max idle to 1, max lifetime to 1h0m0s, max idle time to 3m0s
netbird-management | 2026-01-17T15:37:12Z WARN management/internals/controllers/network_map/controller/controller.go:84: failed to parse NB_EXPERIMENT_NETWORK_MAP, using default value false: strconv.ParseBool: parsing “”: invalid syntax
netbird-management | 2026-01-17T15:37:12Z INFO management/server/idp/embedded.go:200: embedded Dex IDP initialized with issuer: netbird.domain.com/oauth2
netbird-management | 2026-01-17T15:37:12Z WARN management/internals/controllers/network_map/controller/controller.go:626: failed to parse peer update interval, using default value 1ms: strconv.Atoi: parsing “”: invalid syntax
netbird-management | 2026-01-17T15:37:12Z INFO management/internals/controllers/network_map/controller/controller.go:642: set peer update buffer interval to 1ms
netbird-management | 2026-01-17T15:37:12Z INFO management/server/account.go:234: single account mode enabled, accounts number 0
netbird-management | 2026-01-17T15:37:12Z ERRO [keysLocation: localhost:80/oauth2/keys] shared/auth/jwt/validator.go:76: could not get keys from location: Get “localhost:80/oauth2/keys”: dial tcp [::1]:80: connect: connection refused
netbird-management | 2026-01-17T15:37:12Z INFO management/internals/server/server.go:149: running gRPC backward compatibility server: [::]:33073
netbird-management | 2026-01-17T15:37:12Z INFO management/internals/server/server.go:187: management server version 0.63.0
netbird-management | 2026-01-17T15:37:12Z INFO management/internals/server/server.go:188: running HTTP server and gRPC server on the same port: [::]:80
