How can I see if 2 peers are directly connected or going through the relay?
New to Netbird. I have 3 peers setup (a Linux VM, a Windows laptop, and a Android phone). Is there a way to see how 2 peers are connected to each other? Like directly connected or using a relay server? Basically my Linux VM is only showing connections to 4 relay servers but I’m not seeing any other direct connections to peers. Even when 2 devices are on the same vlan in my house, I think it’s still using the relay for some reason.
Found the “netbird status --detail” info in the Linux client at least… I was directly connecting on my local network over v6. But when my phone is on regular 5G/Internet (not wireless), NAT is involved with both ends and it relays. It can’t build a direct tunnel for some reason.
