Hope the NetBird Android App will get better with battery-useage
Hope, that NetBird will get better in barrery-usage.
I have to power up the battery a couple of time to get through the day.
Nobody else having problems with the battery-usage with NetBird?
What device are you using? Is it CONSTANTLY connected to NetBird? Have you tried running without netbird running in the background?
Hello @Nordlicht-13 can you try enabling lazy connections for your network?
Learn more at: Lazy Connections - NetBird Docs
This might reduce battery usage since it will only connect to other peers when there is traffic and when the connection becomes idle it will disconnect again.
I have NeBird as a continuously active VPN.
I have immich, searXNG and Adguard running on my homelab that I use on my mobile device.
Can’t turn of running in background, it gets activated again.
Tailscale was not using that much battery.
Lazy Connection is already enabled under Settings → Clients → Enable Lazy Connections
