I have been fighting with this for some time and I can’t think of anything more now so hopefully someone has an idea on what to try next.
I have my internal network and setup the management server on a box with its own external IP outside of my home network exposed to the web. Everything works great with the serve outside of my network. Can connect, add clients, etc…
Form inside my network though, i cannot access that server. The name of the server is vpn.domain.com and the rest of my network is *.domain.com. All managed by cloudflare.
The odd part is that when i turn on a VPN service such as PIA I can connect to the management server from within my network…
There must something with the DNS or routing but I can’t figure it out. When i do an nslookup of VPN.domain.com from the internal network it gives the proper IP, I can ping it, but can’t access it
Yes i have set the VPN.domain.com on cloudflare. When i do an nslookup it shows the correct IP. I can ping the srrver by IP and domain so the traffic seems to be leaving thr network but maybe not the SSL traffic. Can’t fully figure it out
