Guide on fixing STUN/TURN “Unavailable” on OPNsense
Notes (Read First)
  • If your ISP router is in bridge mode (no double NAT), this works perfectly.
  • If you’re behind CGNAT, NetBird will often fall back to TURN/relay anyway.
  • You don’t need to open inbound ports; all rules are outbound only.
  • If you’re using Unbound with DNSBL/blocklists, make sure stun.netbird.io and turn.netbird.io are whitelisted. Otherwise, they’ll resolve to 0.0.0.0 or a sinkhole.
Symptoms
NetBird daemon shows:
[stun:stun.netbird.io:443] is Unavailable, reason: context deadline exceeded
[stun:stun.netbird.io:5555] is Unavailable, reason: context deadline exceeded
  • Peers only connect via relay, not directly.
Steps
1. Enable Static Port NAT for UDP
By default, OPNsense rewrites UDP source ports which breaks STUN mapping.
We need to preserve the original UDP source port.
  • Go to Firewall → NAT → Outbound
  • Set mode to Hybrid Outbound NAT
  • Add a new rule:
    • Interface: WAN
    • Protocol: UDP
    • Source: This Firewall (or NetBird interface if you want to be specific)
    • Destination: any
    • Translation / target: Interface address
    • Static Port: :white_check_mark: checked
Verify with:
pfctl -s nat
Should show:
nat on igc0 inet proto udp from (self) to any -> (igc0:0) static-port
2. Allow Outbound Firewall Rules for STUN/TURN
  • Go to Firewall → Rules → WAN
  • Add a rule:
    • Action: Pass
    • Interface: WAN
    • Protocol: UDP
    • Source: WAN address (self)
    • Destination: STUN/TURN server IPs
    • Destination Port: 443, 5555
    • Description: Allow NetBird STUN/TURN
How to get the IPs
Run this on OPNsense shell:
drill stun.netbird.io
drill turn.netbird.io
Example:
stun.netbird.io. 60 IN A 34.120.xxx.xxx
turn.netbird.io. 60 IN A 34.149.xxx.xxx
Use those IPs in your firewall alias/rules.
3. Test with stunclient
From a client behind OPNsense:
stunclient stun.netbird.io 443
Expected output:
Binding test: success
Local address: 10.10.10.xxx:xxxxx
Mapped address: <your_public_ip>:<same_port_or_random_port>
4. Verify from OPNsense
Check NetBird status:
netbird status
Should show:
[stun:stun.netbird.io:443] is Available
[stun:stun.netbird.io:5555] is Available
[turns:turn.netbird.io:443?transport=tcp] is Available
  1. Check DNS resolution
drill [stun.netbird.io](http://stun.netbird.io)
  1. Inspect outbound packets with tcpdump
tcpdump -ni wan udp and host [stun.netbird.io](http://stun.netbird.io)
tcpdump -ni wan udp and host turn.netbird.io
  • Packets going out but no replies → ISP or upstream block.
  • Replies seen but NetBird still fails → check NAT static port rule again.
Result
After enabling UDP static-port NAT, whitelisting STUN/TURN in Unbound DNSBL, and creating outbound rules with the correct IPs, NetBird peers can now establish direct P2P connections. Relays are only used when necessary.
Thank you for this !
I wonder which stunclient you use for testing. I work under debian and the stun-client package installs stunwhich has no option to give a port number.
