I have a working Zitadel setup and followed closely the advanced guide for installing Netbird. However, once I login via Zitadel with the admin account, I keep getting an error 500.
Navigate to https://netbird.mydomain.com
Zitadel shows up, authenticate with an account
Redirection to admin dashboard.
Self-hosted.
No.
Netbird is behind a reverse proxy (traefik). The setup I have is roughly the same as described here: https://www.reddit.com/r/selfhosted/comments/xpju6p/comment/iu85hqy/?utm_source=share&utm_medium=web2x&context=3
Looking at the requests, the error is coming from https://netbird.example.com/api/users and https://netbird.example.com/api/users/current.
I checked every log, and didn’t find anything relevant.
[ x ] Reviewed client troubleshooting (if applicable)
[ x ] Checked for newer NetBird versions
[ x ] Searched for similar issues on GitHub (including closed ones)
[ x ] Restarted the NetBird client
[ x ] Disabled other VPN software
[ x ] Checked firewall settings
Xeravax
September 12, 2025, 12:30pm
2
Roughly the same != the same. Preferrably it would be nice to obtain your setup, know how you’ve set it up and the config you use. Otherwise, if you have a single config entry that is different from that post, it woudn’t apply to any of us. Making it harder to figure out what the solution could be.
Sure.
My dynamic_config.yml for traefik:
http:
routers:
netbird:
entryPoints: websecure
rule: Host(netbird.example.com)
tls:
certResolver: letsencrypt
service: netbird
netbirdapi:
rule: Host(`netbird.example.com`) && PathPrefix(`/api`)
tls:
service: netbirdapi
netbirdmanagement:
rule: Host(`netbird.example.com`) && PathPrefix(`/management`)
tls:
service: netbirdmanagement
netbirdsignal:
rule: Host(`netbird.example.com`) && PathPrefix(`/signalexchange`)
tls:
service: netbirdsignal
services:
netbird:
loadbalancer:
passHostHeader: true
servers:
- url: 'http://dashboard:80'
netbirdapi:
loadbalancer:
servers:
- url: 'http://management:33073'
netbirdmanagement:
loadbalancer:
servers:
- url: 'h2c://management:33073'
netbirdsignal:
loadbalancer:
servers:
- url: 'h2c://signal:10000'
Changed values in dashboard service in docker-compose.yml
- NETBIRD_MGMT_API_ENDPOINT=https://netbirdapi.example.com:443
- NETBIRD_MGMT_GRPC_API_ENDPOINT=https://netbirdapi.example.com:443
Changed signal port in management.json
"Signal": {
"Proto": "http",
"URI": "netbird.example.com:443",
"Username": "",
"Password": null
OK, so I managed to fix this by changing the Traefik rules to match the new Netbird API:
netbird:
rule: "Host(`netbird.example.com`)"
service: netbird
entryPoints:
- websecure
tls:
netbirdapi:
rule: "Host(`netbird.example.com`) && PathPrefix(`/api`)"
service: netbirdapi
entryPoints:
- websecure
tls:
netbirdrelay:
rule: "Host(`netbird.example.com`) && PathPrefix(`/relay`)"
service: netbirdrelay
entryPoints:
- websecure
tls:
netbirdmanagement:
rule: "Host(`netbird.example.com`) && PathPrefix(`/management.ManagementService/`)"
entryPoints:
- websecure
tls:
netbirdsignal:
rule: "Host(`netbird.example.com`) && PathPrefix(`/signalexchange.SignalExchange/`)"
entryPoints:
- websecure
tls:
However, I still have issues when trying to setup a peer from an Android phone.
At first there was an issue where the authentication redirect_uri was set to http://localhost:5300 which I’m still not sure what it is reffering to (localhost of Zitadel or Netbird management?) so I had to add the correct URLs in management.json manually:
"RedirectURLs": [
"https://netbird.example.com/auth",
"https://netbird.example.com/silent-auth",
"http://localhost:53000"
Now, when trying to connect with the Android app, I’m redirected to the Zitadel login page, but after I connect I receive a login error saying “Oops, something went wrong unauthenticated”.
This only happens with the Android app, I managed to connect a Linux device without any problems.
