Edit existing Network Routes
I always get frustrated when I try to edit my network routes because I can’t change the IP address or domain, nor can I add an IP address or domain to an existing network route.
I have to delete the route first before I can create it again to add another IP address or domain.
Is it possible to add a feature that allows you to add an IP address or domain to an existing network route?
Is there a specific reason you need routes and not just use “Networks”?
Same issue, smallest change have to delete and recreate. One use case is Personally we still use exit nodes which are only under “Network Routes” If I am not mistaken.
