Disable LAN access in exit nodes
G’day,
I’d like to be able to have an exit node to access the internet (WAN IPs, google, etc) without people being able to access other devices on the LAN of the exit node (eg. the firewall on my network).
  1. Create an exit node network route
  2. Use a device on a different network to test the exit route and try to access a LAN device (eg. 192.168.1.1)
No access to private IP addresses. Preferably by default but maybe using an ACL
No, this is a self hosted version
I think that should be possible by having no ACL at all for this. Or putting up a VLAn internally to be able to block any connections from going out to the LAN, and only be able to go out to WAN>
G’day,
I tried setting as both an EXIT node and a regular routing node. With the exit node, it didn’t have any ACL rules but I could use another device to access 192.168.1.1 via the exit node. I then tried using it as a regular routing node but there doesn’t seem to be a way to allow all but some IP addresses (eg ALLOW 0.0.0.0/0 BLOCK 192.168.1.0/24).
You can use the --block-lan-access flag on the routing peer, which will block access to connected subnets. I.e.
netbird down
netbird up --block-lan-access
Alternatively, you can use drop policies (API only)
