I have an environment with several separate netbird networks and thinking about ways to interconnect those.
This is not about switching profile, but connecting two netbird networks via a gateway/router.
I wonder if somethhing like the following is possible. I have not yet tried it out, though. Just idle thinking at the momemt. Playing around with some ideas
- Netbird network A with a routing peer (A1) on an own docker container
- Netbird network B with a routing peer (B1) on an own docker container
- Both routing peers (A1, B1) are connected via private docker network to a FRRouter docker container (R)
- Once A1 connects, it gets available routes and peers based on Netbird A policies
- Once B1 connects, it gets available routes and peers based on Netbird B policies
- FRRouter would get the routes via OSPF and hence routes according to the configuration.
- I believe this is something about FRR’s zebra daemon which gets the routes of the wireguard interface on A1 and B1. Using a Dockerfile that builds A1 and B1 from frrouting/frr:v9.1.0 and installs netbird should probably already make sure that the routes can be extracted via “redistribute kernel”
- A1 and B1, as well as R should have ip forwarding allowed.
- OSPF setup to dynamically announce the correct routes.
- Routes to be announced to the other side are based on the routes either netbird client receives. And that is dependant of the policies set in A and B respectively.
Possible problems:
Duplicate IP Address/subnet leading to routing issues. I do not know how IP assigning to netbird clients work in detail, but since a Netbird network is usually selfcontained, there might be a chance that several instances assign the same IP address to nodes. It’s a similar issue like trying to connect two identical home subnets via VPN.
Policy rules apply to one Netbird instance only. So, the policies need to be very carefully crafted on both sides. Since I have control over both sides, that risk should be controllable.
Beside that, would something like that actually fly?
Dan
