Change stun port
hi, installed self hosted using the install script
realised port 3478 is already taken up by another service
can i rerun the install script specifying a different port number?
thanks
There should be an option in the client to change the port you are using. If you are using a different port on the netbird server itself. You should be able to change the docker compose file in /opt/netbird.
