Cannot access web interface after VPS image restore
Using the VPS provider’s control panel, I took a backup of the VPS when Netbird was properly functioning. I did this so that I could restore the image if things went wrong when I attempted to add other services onto the server. After restoring the image, I get 404 and intermittent 502 errors when attempting to access the Netbird webadmin.
However, all clients can connect and seem to be functioning as they should.
  1. Go to ‘netbird.example.com’
  2. See nothing but 404 or 502 error
Be prompted to login to the Netbird webadmin.
Self-hosted
v0.79.0
netbird status -dA
  [INFO] SYSTEM (31b4f8b3-e7a5-4615-a520-96d8fad51d40)
    Message: daemon config changed (source=startup)
    Time: 6 hours, 36 minutes ago
    Metadata: source: startup, type: config_changed
  [INFO] SYSTEM (922e1302-2d2f-4bda-9cf3-2d571107e880)
  [INFO] SYSTEM (9bae40c5-571c-4d40-9245-fe197c2f38bd)
    Time: 6 hours, 26 minutes ago
OS: linux/amd64
Daemon version: 0.79.0
CLI version: 0.79.0
Management: Connected to https://nb.anon-9Th8J.domain:443
Signal: Connected to https://nb.anon-9Th8J.domain:443
  [stun:nb.anon-9Th8J.domain:3478] is Available
  [rels://nb.anon-9Th8J.domain:443] is Available via ws
FQDN: nb.netbird.selfhosted
NetBird IP: 100.64.116.206/16
NetBird IPv6: 2001:db8:ffff::/64
Interface type: Kernel
Wireguard port: 49022
Lazy connection: true
Peers count: 0/0 Connected
netbird debug for 1m -AS -U
aa1fd1a05ed1f058cbd4b6fc939a97957cbac02ae15e0297b5011ff5e813f55a/587c1034-c319-4213-b4c3-74fd2cb2791f
If applicable, add screenshots to help explain your problem.
[root@nb ~]# docker ps
CONTAINER ID   IMAGE                             COMMAND                  CREATED         STATUS                           PORTS        NAMES
aa51245b4607   netbirdio/reverse-proxy:latest    "/go/bin/netbird-pro…"   3 minutes ago   Up 3 minutes                     8443/tcp, 0.0.0.0:51820->51820/udp, [::]:51820->51820/udp                      netbird-proxy
8919e3b4a2d7   crowdsecurity/crowdsec:v1.7.7     "/bin/bash /docker_s…"   3 minutes ago   Up 3 minutes (healthy)        netbird-crowdsec
cb18ac31e80a   traefik:v3.6                      "/entrypoint.sh --lo…"   3 minutes ago   Up 3 minutes                     0.0.0.0:80->80/tcp, [::]:80->80/tcp, 0.0.0.0:443->443/tcp, [::]:443->443/tcp   netbird-traefik
614fd212c890   netbirdio/dashboard:latest        "/usr/bin/supervisor…"   3 minutes ago   Restarting (139) 5 seconds ago        netbird-dashboard
647b54b5cfee   netbirdio/netbird-server:latest   "/go/bin/netbird-ser…"   3 minutes ago   Up 3 minutes                     0.0.0.0:3478->3478/udp, [::]:3478->3478/udp                                    netbird-server
[root@nb ~]# docker network ls
NETWORK ID     NAME           DRIVER    SCOPE
141a829dd9b2   bridge         bridge    local
acf4b65e7a74   host           host      local
88b57d0bbb55   none           null      local
19d0724fa1ad   root_netbird   bridge    local
[root@nb ~]# docker network inspect root_netbird | grep -A 2 Containers
        "Containers": {
            "647b54b5cfee65db36d94ca722805b4cd36350dbf079494e8b8442f33e55766d": {
                "Name": "netbird-server",
[root@nb ~]# docker network inspect bridge | grep -A 2 Containers
        "Containers": {},
        "Status": {
            "IPAM": {
I’m guessing it has something to do with the Docker network specified for the Netbird containers. Maybe local IP’s have been reassigned differently to the containers??? I’m saying this because I have encountered that issue with other Docker stacks, on other servers. The way I fixed it was to use the service names instead of the IP addresses in the reverse-proxy settings. Then if the IP’s assigned to the containers ever changed, everything still worked. Anyway, I really need help troubleshooting. I don’t know where to begin.
You might have restored back to a point of the old netbird containers with some new version of netbird, however. I am not sure of this, could also be a reverse proxy issue. What is your setup like rn in terms of the webserver u use?
I worked on it for hours and never found the cause so I reinstalled the server OS and started all over.
