Agent Network Cant Connect To Endpoint (Timeout)
I add providers to the agent network, Add a policy allowing my group to access it and it generates an API BASE URL, but when I try to use a curl to test it it just sits there and then eventually times out. When I do an nslookup to that name it resolves to an internal netbird IP.
I cant find much info on this feature or documentation besides basic explanation of what it is and how it works.
I installed it using the getting started script.
This is not a new installation, I used the NETBIRD_AGENT_NETWORK_ENABLED=true variable
Thanks ahead of time for anyone that can help me get this actually working.
EDIT in the netbird-proxy logs container I see it getting a certificate for the endpoint but after its stating “WARN proxy/internal/acme/manager.go:475: notify certificate ready for domain “REDACTED”: rpc error: code = NotFound desc = service agent-net-svc-d7j7r0fiplls738c4s5g not found”
