Access device on the local WLAN (WiFi) not over Birdnet
Is there a way to access a device on the local WLAN (WiFi)
without using the Birdnet.
I have a TV that I can control with an app, this only works,
when I disconnect the android-phone from the Birdnet.
In Tailscale I have a App split tunneling to let selected apps
access the internet directly, without using Tailscale.
Is something like this possible in Netbird, or are there any
plans for something like this?
As far as the Netbird application goes, not that I recall. However I recommend making this a Feature Requests. Apart from that, if you need something that has it implemented, an alternative open source implementation of the client can be used here:
From what I saw, that app works with any Netbird provider and will give you the split app tunneling feature as requested.
