Access control rules in the reverse proxy section
Hello community,
I’m running netbird as a self-hosted docker instance on a VPS. Is it possible to change the order of the access control rules in the Access Control section of the reverse proxy? My ACL rule currently looks like this:
  1. Allow only → IP address → 172.x.x.x
  2. Allow only → country → “dedicated country”
    …the IP address rule always jumps to the top, taking the first position…
    However, the order needs to be such that the “Country” access rule is the first rule, and the “IP Address” rule is the second.
    Is this possible? Can the order of the access control rules be changed manually?
Thanks for your help…
To Reproduce**
  1. Go to ‘reverse proxy’
  2. Click on ‘Services’
  3. go to ‘Access Control’
  4. add rules
no, self hosted on a VPS
no
Is there anyone here who can help? Or give me an idea of how to solve this?
There is no order, “allow only” means that it checks if the condition is valid and if any condition in that list is valid. It allows stuff through. Instead of checking if every condition validates. You’d have to put it in the same rule for it to do multiple checks.
