Installed the new beta version of netbird client for android
Loving all the new feature added like available networks and ability to disable subnet/dns when needed all are welcome addition
But even now exit node is depended on policies and doesn’t have an option weather to accept or reject exit node
A toggle like that exist for dns and subnet should there be a toggle for accepting exit node separate of subnets
Currently I attach the Machine I need exit node to VPN tag to get exit node working
