I recently set up a Stalwart E-Mail server on my Netcup VPS. This required me to open several ports for e-mail, such as port 25, and ports 80 and 443 for HTTPs.
I also wanted to use the same VPS for Netbird. Today, I installed Netbird with option 0 for the built-in Traefik reverse proxy. Shortly before I set Netbird up, I changed Stalwart’s HTTPS port from 443 to 4443 so Netbird can occupy 443. I thought I could use Netbird’s reverse proxy to easily link my mail domain to my Stalwart instance. I think TLS forwarding will do the trick so Stalwart can generate certificates on its own. Unfortunately, though, I only saw options to choose peers and networks as targets, not localhost or local docker networks. I spent several hours trying to figure out how to achieve my goal, without success.
No. This server is self-hosted.
NetBird version:
Management: v0.76.3
Dashboard: v2.90.9
This is my docker compose file for Stalwart:
services:
stalwart:
image: stalwartlabs/stalwart:v0.16
container_name: stalwart
restart: unless-stopped
ports:
- “25:25”
- “465:465”
- “587:587”
- “993:993”
- “4190:4190”
- “4443:443”
- “8080:8080”
volumes:
- stalwart-etc:/etc/stalwart
- stalwart-data:/var/lib/stalwart
volumes:
stalwart-etc:
stalwart-data:
- Reviewed client troubleshooting (if applicable) (This is not a client)
- Restarted the NetBird client (This is not a client)
- Disabled other VPN software (There is no other VPN software)
- Checked firewall settings (This is not my problem)
